AV10 exhaust mods
Alan Jackson /
has anyone sucessfully modded one of these?
sold as MOBYLETTE, MOTOBECANE, MOTOCONFORT, MBK 41/51/881 SUPER APRES EXHAUST SILENCER (BLACK)
im getting up to 45mph GPS just down my street with this fitted but its got to be the weakest link
82 cc parmakit and 19mm phbg
Re: AV10 exhaust mods
Best person to answer your question would be Rebel Moby, ping a PM, he's helped me out loads with moby tuning advice.
That pipe is designed for regulatory compliance and not speed. All the potential of a 19mm carb is being throttled down by a tiny exit on the silencer.
If you still have the stock AV10 silencer you can modify that, but you need to keep in mind there is a balance between performance (noisier) and neighbour tolerance (quieter).
Alan Jackson /
my bike was a 50v with av7 engine and exhaust so ive never owned an av10 std pipe.
im guessing i fit a larger exit pipe and make sure the holes in the inner baffle are something like on the mods to other pipes?
Wait so you don't have an av10? Just the exhaust?
Err, will it even fit an av7? That bend looks tight compared to the cashew I've got and I had to notch mine to miss the crankcase.
Alan Jackson /
bike was a 50 v with an av7 motor and av7 exhaust
you with me?
i fitted a parmakit 82cc motor (av10) (dont think they do av7?)
and needed an exhaust.
you still with me?
so i bought the exhaust in the pic cos my av7 exhaust wouldnt fit.
still there?
so you can see how ive never owned a std av10 pipe.
anyway none of that matters. i just need to know if this pipe is moddable.
Totally normal JBOT /
Everything can be changed if you have metal working tools.
Those cashew pipes get really loud when you mod them. Sometimes louder than a tuned exhaust.
If you’re running an 82cc engine, you should throw a real pipe on there.
Yeah you can mod it, but regardless it's gonna steal a ton of power. Although if your fine with that it's still gonna be quicker than a stock bike.
That being said, it will never be as good as an expansion chamber. You would blast with a good pipe.
Alan Jackson /
fiited a streetcup doppler but i think its tuned to higher revs than my 7k rpm porting
from a 10mph rolling start im hitting 49mph gps after 400 metres and im happy enough as its still accelerating so maybe low 50's.
halfway through making my own pipe at the weld stage. i've been putting it off.
Olá meu amigo. Posso responder com uma pergunta? Sou novo por Aki.. poderia me dizer se fiz a escolha certa para meu mbk51 de um ninja g3 na respectiva config. Kit Athena/eurocilindro 47mm
(Ainda estou com) 2palhetas malossi e coletor malossi 21
Phbg 21mm agulha w16 (Será q vai dar excesso?) Kkk já ouvi falar Aki sobre isso.
Vira brequinho doppler er1
Taxa na cabeça 11.1
Ignição original
É isso. Será q o ninja g3 vai segura os altos diagramas stock do eurocilindro 175/130?
Ainda n ligou. Está na bancada. Tive entrada de ar mas já foi corrigido. Meu phbg tá 90 60 45 e w16 . Minha dúvida é será q vai alimentar esse phbg21? E o escape vai girar 9000 aproximadamente?
Bom é isso. Obrigado e me desculpe pelo texto. (edited)
> sobre isso.
> Taxa na cabeça 11.1
> Ignição original
Translated :
Hello my friend. Can I answer with a question? I'm new to Aki .. could you tell me if I made the right choice for my mbk51 of a ninja g3 in the respective config. Athena kit / eurocylinder 47mm
(I'm still with) 2 malossi picks and malossi collector 21
Phbg 21mm needle w16 (Is it going to overflow?) Kkk I've heard Aki talk about it.
Turn brequinho doppler er1
Head rate 11.1
Original ignition
That's it. Will the ninja g3 secure the high stock diagrams of the 175/130 eurocylinder?
You haven't called yet. It's on the bench. I had air intake but it has already been corrected. My phbg is 90 60 45 and w16. My question is will q will feed this phbg21? And the exhaust will turn 9000 approximately?
That’s good. Thank you and I'm sorry for the text.
Alan Jackson /
i think you should start a new thread Lucas Ribeiro
can someone translate that for him please?
Here ya go :
Alan Jackson / aljaxon
18 de maio de 2021 14h54
Acho que você deveria começar um novo tópico Lucas Ribeiro
Alan Jackson /
thanks
