Re: Super Awesome Trac DP50 Cheat Codes
DAЯT _ /
So currently I’m using PLA while I’m prototyping. Gonna wit carbon fiber impregnated PETG next, which should be perfect. Both will hold up to fuel but PLA actually is not sealed to gasoline vapors. Kinda like iodine in a plastic bag. As far as the bigger carb goes these engines are teeny carbs from the factory. I’m gonna play with the jetting a bit for sure. The head gaskets do look strikingly similar between these engines and Yamaha engines. I took some measurements when I had the head off.
