Re: Nc50 cdi on a pa50?
Nick MBC /
> Aaron Blair Wrote:
> If your tapers clean and goodly you shouldn't need the key. Basically
> never ran them on my mobys...or was it vespas? Maybe both!lol
> Regardless if the flywheel taper and crank taper are in good shape
> you'll be ok methinks. I'd be surprised if the key is in the same place
> for both bikes.
> Wait, diddnt a guy use electric start express case halves and crank to
> make an electric start hobbitt here a few wears ago? Or was the starter
> gear on the variator side.... huh
People do use electric start express right side cases to do that, good point. So this almost definitely works.
