Re: Hobbit inner front pulley cheek. Has anyone tried to remove it?
Totally normal JBOT /
You cannot do it.
However.
You can chuck it up in a lathe and make it substantially more steep, which also extends the boss. It’s the BEST mod for wicked acceleration, and can allow wider belts to sit lower in the V. I’ve pushed the boss back by about 3mm then “steepened” the cheek angle from that point to the existing outer edge.
That doesn’t mean your BX belt is good tho cuz they suck shit. It does allow a more narrow belt to ride much higher in the cheeks than at stock cheek angle
