Re: The design of a new puch cylinder
Graham Motzing /
When designing a casting you design the part, then you design the mold, then you design the tool to form the mold. It helps to think of the plaster mold as a finished product in itself, then think of the tool as a finished product. In order to make the part fill correctly, you must follow Campbells rules for casting, if you want to get into casting it’s the cheat codes and 10 commandments all rolled into one, go read it. I’ve been thinking about mold flow for casting a cylinder for 5+ years while taking long poops or deer hunting or watching rom-coms with my wife so I have a pretty good plan for this, which I shared with Jurrian.
The sprue is where the molten metal enters the mold. You want to think of this like a beer bong. You know how when you do a beer bong right the beer goes down as a solid slug of liquid, and when you do it wrong it gets all mixed with air and foamy? Exactly. Air mixing into molten metal causes little fragments of aluminum oxide skin to form which shows up as porosity which is bad. To avoid this you want to have a smooth pour that fills the sprue completely. By running the sprue down the middle of the part you will get good flow everywhere and also the sprue will stay hot, allowing the mold to continue to fill as the metal cools and shrinks. You always want to have a gooey center to your casting so you don’t get shrinkage voids.
The next feature is a large well in the bottom, this will capture any debris and let the liquid metal settle down before evenly filling the mold from the bottom. You always fill from the bottom so the air gets pushed up. As the mold fills, the molten aluminum will combust deposits on the surface, especially residual burnt plastic, so you need to give that a chance to rise. If the aluminum is above the burning plastic, those gasses will get trapped and cause more flaws. This is why you never ever ever pour straight onto the top of a mold, it just doesn’t work and if the gasses are bad enough it can pop and spatter in your face.
The flow from the well into the actual part itself is very important, you need a single ‘front’ like a wave. Anywhere the aluminum is being exposed to air it will form that oxide skin, so its kinda like when you see lava going into the ocean. If two ‘waves’ come back together the skin will keep them from knitting and you will get weird knit lines which are a significant weakness in the part. If the wave moves fast and in a single smooth motion, the aluminum behind the wave will still be hot enough to incorporate and you won’t have that problem. For the cylinder using the entire base gasket surface makes the most sense.
At the top, the mold will be open-faced. This means the whole top surface will be open to the atmosphere. This is used in submersion casting and is probably how real 2t cylinders are cast in permanent molds. This way the entire top surface becomes a riser that will be cut off and any imperfections get chopped off in machining. It’s a lot more metal waste and machining time, but when you need a very high quality casting this is the best way to do it. Also, this way the mold will burn out upside down and everything will come out. When you burn out the PLA, anywhere it sits it will soak into the plaster almost like oil, and burn when it gets hit with molten aluminum.
  The design of a new puch cylinderTopic by: Jurrian Mulder Jurrian Mulder 01/14/21 09:11AM
  Re: The design of a new puch cylinderRe: Beach Club Nick Beach Club Nick 01/14/21 09:13AM
  Re: The design of a new puch cylinderRe: Jurrian Mulder Jurrian Mulder 01/14/21 09:17AM
  Re: The design of a new puch cylinderRe: Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F 01/14/21 09:55AM
  Re: The design of a new puch cylinderRe: Graham Motzing Graham Motzing 01/14/21 10:16AM
  Re: The design of a new puch cylinderRe: Probably Fred Probably Fred 01/14/21 11:52AM
  Re: The design of a new puch cylinderRe: Dirty30 Dillon Dirty30 Dillon 01/14/21 01:48PM
  Re: The design of a new puch cylinderRe: Jurrian Mulder Jurrian Mulder 01/14/21 01:56PM
  Re: The design of a new puch cylinderRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 01/14/21 12:50PM
  Re: The design of a new puch cylinderRe: Jurrian Mulder Jurrian Mulder 01/14/21 02:02PM
  Re: The design of a new puch cylinderRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 01/14/21 08:16PM
  Re: The design of a new puch cylinderRe: operator error 696 420 operator error 696 420 01/15/21 08:45PM
  Re: The design of a new puch cylinderRe: operator error 696 420 operator error 696 420 01/14/21 01:26PM
  Re: The design of a new puch cylinderRe: Johnny Braaapp Johnny Braaapp 01/15/21 09:47AM
  Re: The design of a new puch cylinderRe: 🦺🥇b to the MOPO 🚨🚨🚨 eff 🦺🥇b to the MOPO 🚨🚨🚨 eff 01/15/21 10:47AM
  Re: The design of a new puch cylinderRe: Josh G Josh G 01/15/21 01:27PM
  Re: The design of a new puch cylinderRe: Jurrian Mulder Jurrian Mulder 03/29/21 04:33AM
  Re: The design of a new puch cylinderRe: Jurrian Mulder Jurrian Mulder 11/29/21 09:17AM
  Re: The design of a new puch cylinderRe: Josh G Josh G 03/29/21 07:47PM
  Re: The design of a new puch cylinderRe: Probably Fred Probably Fred 03/29/21 08:34PM
  Re: The design of a new puch cylinderRe: Josh G Josh G 11/29/21 02:00PM
  Re: The design of a new puch cylinderRe: Jurrian Mulder Jurrian Mulder 11/29/21 04:11PM
  Re: The design of a new puch cylinderRe: Graham Motzing Graham Motzing 11/29/21 05:18PM
  Re: The design of a new puch cylinderRe: Eric Davenport Eric Davenport 11/29/21 05:36PM
  Re: The design of a new puch cylinderRe: Jesse Stephenson Jesse Stephenson 11/29/21 07:07PM
  Re: The design of a new puch cylinderRe: Josh G Josh G 11/30/21 02:20PM
  Re: The design of a new puch cylinderRe: Dickie Gila Dickie Gila 11/30/21 10:24PM
  Re: The design of a new puch cylinderRe: Graham Motzing Graham Motzing 12/01/21 12:05AM
  Re: The design of a new puch cylinderRe: LSLB RXb LSLB RXb 12/01/21 12:03PM
  Re: The design of a new puch cylinderRe: Graham Motzing Graham Motzing 11/30/21 06:40PM
  Re: The design of a new puch cylinderRe: Graham Motzing Graham Motzing 11/30/21 06:41PM
  Re: The design of a new puch cylinderRe: Oil Stainz Oil Stainz 12/01/21 01:06AM
  Re: The design of a new puch cylinderRe: Graham Motzing Graham Motzing 12/01/21 11:12AM
  Re: The design of a new puch cylinderRe: E BinOH E BinOH 12/01/21 12:55PM
  Re: The design of a new puch cylinderRe: Dickie Gila Dickie Gila 12/01/21 01:49PM
  Re: The design of a new puch cylinderRe: Josh G Josh G 12/01/21 03:46PM
  Re: The design of a new puch cylinderRe: Jurrian Mulder Jurrian Mulder 12/01/21 03:52PM
  Re: The design of a new puch cylinderRe: Jay Rivett Jay Rivett 12/03/21 11:02AM
  Re: The design of a new puch cylinderRe: Graham Motzing Graham Motzing 12/03/21 02:11PM
  Re: The design of a new puch cylinderRe: Graham Motzing Graham Motzing 12/06/21 10:01AM
  Re: The design of a new puch cylinderRe: nick s nick s 12/03/21 01:29PM
  Re: The design of a new puch cylinderRe: nick s nick s 12/06/21 03:14PM
  Re: The design of a new puch cylinderRe: Graham Motzing Graham Motzing 12/06/21 04:13PM
  Re: The design of a new puch cylinderRe: daan SJAARLOOS daan SJAARLOOS 12/09/21 08:15AM
  Re: The design of a new puch cylinderRe: Douglas Binder Douglas Binder 12/09/21 08:28AM
  Re: The design of a new puch cylinderRe: Graham Motzing Graham Motzing 12/09/21 09:54AM
  Re: The design of a new puch cylinderRe: nick s nick s 12/06/21 04:48PM
  Re: The design of a new puch cylinderRe: Graham Motzing Graham Motzing 12/06/21 05:12PM
  Re: The design of a new puch cylinderRe: Josh G Josh G 12/07/21 02:31PM
  Re: The design of a new puch cylinderRe: Graham Motzing Graham Motzing 12/07/21 03:56PM
  Re: The design of a new puch cylinderRe: Josh G Josh G 12/07/21 07:28PM
  Re: The design of a new puch cylinderRe: Graham Motzing Graham Motzing 12/07/21 08:26PM
  Re: The design of a new puch cylinderRe: Jurrian Mulder Jurrian Mulder 12/08/21 03:18AM
  Re: The design of a new puch cylinderRe: Jurrian Mulder Jurrian Mulder 12/08/21 04:45AM
  Re: The design of a new puch cylinderRe: Graham Motzing Graham Motzing 12/08/21 10:38AM
  Re: The design of a new puch cylinderRe: Douglas Binder Douglas Binder 12/08/21 11:12AM
  Re: The design of a new puch cylinderRe: Jurrian Mulder Jurrian Mulder 12/08/21 01:58PM
  Re: The design of a new puch cylinderRe: Graham Motzing Graham Motzing 12/08/21 02:31PM
  Re: The design of a new puch cylinderRe: Josh G Josh G 12/08/21 02:33PM
  Re: The design of a new puch cylinderRe: Graham Motzing Graham Motzing 12/08/21 02:39PM
  Re: The design of a new puch cylinderRe: Graham Motzing Graham Motzing 12/08/21 08:44PM
  Re: The design of a new puch cylinderRe: P D P D 12/08/21 08:50PM
  Re: The design of a new puch cylinderRe: Josh G Josh G 01/12/22 04:50PM
  Re: The design of a new puch cylinderRe: Jurrian Mulder Jurrian Mulder 01/13/22 02:47AM
  Re: The design of a new puch cylinderRe: Graham Motzing Graham Motzing 01/13/22 09:48AM
  Re: The design of a new puch cylinderRe: Jay Rivett Jay Rivett 01/13/22 10:38AM
  Re: The design of a new puch cylinderRe: Graham Motzing Graham Motzing 01/13/22 12:54PM
  Re: The design of a new puch cylinderRe: P D P D 01/13/22 08:22PM
  Re: The design of a new puch cylinderRe: Graham Motzing Graham Motzing 01/23/22 04:26PM
  Re: The design of a new puch cylinderRe: Graham Motzing Graham Motzing 01/23/22 05:51PM
  Re: The design of a new puch cylinderRe: James P James P 01/23/22 06:04PM
  Re: The design of a new puch cylinderRe: Graham Motzing Graham Motzing 01/24/22 12:45PM
  Re: The design of a new puch cylinderRe: Douglas Binder Douglas Binder 02/14/22 03:23PM
  Re: The design of a new puch cylinderRe: Graham Motzing Graham Motzing 02/14/22 05:49PM
  Re: The design of a new puch cylinderRe: Douglas Binder Douglas Binder 02/15/22 11:46AM
  Re: The design of a new puch cylinderRe: Graham Motzing Graham Motzing 02/15/22 01:05PM
  Re: The design of a new puch cylinderRe: Jay Rivett Jay Rivett 02/15/22 11:10AM
  Re: The design of a new puch cylinderRe: Graham Motzing Graham Motzing 02/15/22 11:19AM
  Re: The design of a new puch cylinderRe: Josh G Josh G 01/24/22 02:36PM
  Re: The design of a new puch cylinderRe: Graham Motzing Graham Motzing 01/24/22 03:05PM
  Re: The design of a new puch cylinderRe: Josh G Josh G 01/24/22 03:52PM
  Re: The design of a new puch cylinderRe: Graham Motzing Graham Motzing 01/24/22 05:32PM
  Re: The design of a new puch cylinderRe: ALAN REA ALAN REA 01/24/22 05:49PM
  Re: The design of a new puch cylinderRe: Jurrian Mulder Jurrian Mulder 01/25/22 04:22AM
  Re: The design of a new puch cylinderRe: Jurrian Mulder Jurrian Mulder 01/16/23 03:57AM
  Re: The design of a new puch cylinderRe: Josh G Josh G 02/14/22 07:00PM
  Re: The design of a new puch cylinderRe: Graham Motzing Graham Motzing 02/14/22 09:25PM
