Re: Another A55 build
Graham Motzing /
The shudder is 100 % caused by that missing spring, it keeps the one way clutch in mesh. If you don't have it, the second gear will engage, the 1 way bearing will release, then the clutch will disengage, then the bearing will grab, then the clutch will grab, then the bearing will release.... Over and over, Causing the shudder. If you haven't yet, check out the a35 manual posted online, it's got a reply good drawing showing how the trans works.... It's kind of a trip, took me years to actually understand what is happening in there.
Eventually that hammertime will chew up the cast iron soft counter shaft gears and also destroy the one way clutch/bearing Cracking the gear housing. If your gears are chipped, your one way bearing housing is probably already cracked. The chipped gears isn't actually that bad, I've run chipped gears before, as long as you fix the underlying issue. The gears are iron on purpose so they will be sacrificial and not chew up the clutch bell gears which are steel. If it was steel on steel and you had a chip like in a differential, they would quickly destroy each other.
I dunno about that airsal kit, I've never built one but the ones I've ridden are lackluster. I would start by making a degree wheel and plotting out the port timing. Go a little wider on the exhaust and get it up to like 150 deg. There is no reason it can't rip.
  Another A55 buildTopic by: Josh Meyer Josh Meyer 01/14/21 01:17AM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/14/21 01:23AM
  Re: Another A55 buildRe: Chris Straub Chris Straub 01/14/21 03:00AM
  Re: Another A55 buildRe: pat splat pat splat 01/14/21 11:19AM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/14/21 11:25AM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/14/21 11:27AM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/14/21 11:31AM
  Re: Another A55 buildRe: Probably Fred Probably Fred 01/14/21 05:25PM
  Re: Another A55 buildRe: LSLB RXb LSLB RXb 01/14/21 05:42PM
  Re: Another A55 buildRe: Graham Motzing Graham Motzing 01/15/21 08:32PM
  Re: Another A55 buildRe: Jay Rivett Jay Rivett 01/16/21 11:15AM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/16/21 11:31AM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/18/21 10:31PM
  Re: Another A55 buildRe: LSLB RXb LSLB RXb 01/19/21 03:14PM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/19/21 03:20PM
  Re: Another A55 buildRe: Graham Motzing Graham Motzing 01/20/21 12:17PM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/20/21 05:34PM
  Re: Another A55 buildRe: Johnny Braaapp Johnny Braaapp 01/19/21 03:43PM
  Re: Another A55 buildRe: LSLB RXb LSLB RXb 01/19/21 03:59PM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/20/21 05:36PM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/20/21 05:52PM
  Re: Another A55 buildRe: Totally normal JBOT Totally normal JBOT 01/20/21 09:30PM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/20/21 09:51PM
  Re: Another A55 buildRe: Johnny Braaapp Johnny Braaapp 01/20/21 10:24PM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/20/21 10:48PM
  Re: Another A55 buildRe: Totally normal JBOT Totally normal JBOT 01/21/21 02:10AM
  Re: Another A55 buildRe: Matt Mulligan Matt Mulligan 01/21/21 02:44AM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/21/21 05:06AM
  Re: Another A55 buildRe: Jackerz ! Jackerz ! 01/22/21 06:40PM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/22/21 07:01PM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/25/21 08:51PM
  Re: Another A55 buildRe: Graham Motzing Graham Motzing 01/26/21 05:51PM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/26/21 05:57PM
  Re: Another A55 buildRe: Graham Motzing Graham Motzing 01/26/21 10:46PM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/26/21 11:01PM
  Re: Another A55 buildRe: Graham Motzing Graham Motzing 01/27/21 11:48AM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/27/21 12:00PM
  Re: Another A55 buildRe: Graham Motzing Graham Motzing 01/27/21 01:16PM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/27/21 01:48PM
  Re: Another A55 buildRe: The Real Mike D The Real Mike D 01/27/21 03:19PM
  Re: Another A55 buildRe: Graham Motzing Graham Motzing 01/27/21 04:15PM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/27/21 05:06PM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/27/21 07:18PM
  Re: Another A55 buildRe: Graham Motzing Graham Motzing 01/27/21 11:50PM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/28/21 12:38AM
  Re: Another A55 buildRe: Graham Motzing Graham Motzing 01/28/21 09:28AM
  Re: Another A55 buildRe: Jay Rivett Jay Rivett 01/28/21 12:27PM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/28/21 12:29PM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/28/21 11:04PM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/26/21 03:41PM
