Re: Another A55 build
LSLB RXb /
a lighter flywheel isn't going to help with making more RPMs. an ignition will not get you more RPMs unless the CDI box is limited or it is timed wrong.
I'd suggest getting a flywheel from an earlier model tomos 4-pole CDI, ditching the hall sensor and using a Parmakit CDI box. They are known to be unlimited as far as RPMs go and have a great timing curve.
and even after all that, an unlimited RPMs CDI setup will only net you more RPMs if you are already hitting the rev limiter on the stock setup.
your other options are raising the exhaust port through piston modification or cylinder porting or getting an exhaust pipe with a shorter tuned length.
  Another A55 buildTopic by: Josh Meyer Josh Meyer 01/14/21 01:17AM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/14/21 01:23AM
  Re: Another A55 buildRe: Chris Straub Chris Straub 01/14/21 03:00AM
  Re: Another A55 buildRe: pat splat pat splat 01/14/21 11:19AM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/14/21 11:25AM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/14/21 11:27AM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/14/21 11:31AM
  Re: Another A55 buildRe: Probably Fred Probably Fred 01/14/21 05:25PM
  Re: Another A55 buildRe: LSLB RXb LSLB RXb 01/14/21 05:42PM
  Re: Another A55 buildRe: Graham Motzing Graham Motzing 01/15/21 08:32PM
  Re: Another A55 buildRe: Jay Rivett Jay Rivett 01/16/21 11:15AM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/16/21 11:31AM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/18/21 10:31PM
  Re: Another A55 buildRe: LSLB RXb LSLB RXb 01/19/21 03:14PM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/19/21 03:20PM
  Re: Another A55 buildRe: Graham Motzing Graham Motzing 01/20/21 12:17PM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/20/21 05:34PM
  Re: Another A55 buildRe: Johnny Braaapp Johnny Braaapp 01/19/21 03:43PM
  Re: Another A55 buildRe: LSLB RXb LSLB RXb 01/19/21 03:59PM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/20/21 05:36PM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/20/21 05:52PM
  Re: Another A55 buildRe: Totally normal JBOT Totally normal JBOT 01/20/21 09:30PM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/20/21 09:51PM
  Re: Another A55 buildRe: Johnny Braaapp Johnny Braaapp 01/20/21 10:24PM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/20/21 10:48PM
  Re: Another A55 buildRe: Totally normal JBOT Totally normal JBOT 01/21/21 02:10AM
  Re: Another A55 buildRe: Matt Mulligan Matt Mulligan 01/21/21 02:44AM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/21/21 05:06AM
  Re: Another A55 buildRe: Jackerz ! Jackerz ! 01/22/21 06:40PM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/22/21 07:01PM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/25/21 08:51PM
  Re: Another A55 buildRe: Graham Motzing Graham Motzing 01/26/21 05:51PM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/26/21 05:57PM
  Re: Another A55 buildRe: Graham Motzing Graham Motzing 01/26/21 10:46PM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/26/21 11:01PM
  Re: Another A55 buildRe: Graham Motzing Graham Motzing 01/27/21 11:48AM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/27/21 12:00PM
  Re: Another A55 buildRe: Graham Motzing Graham Motzing 01/27/21 01:16PM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/27/21 01:48PM
  Re: Another A55 buildRe: The Real Mike D The Real Mike D 01/27/21 03:19PM
  Re: Another A55 buildRe: Graham Motzing Graham Motzing 01/27/21 04:15PM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/27/21 05:06PM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/27/21 07:18PM
  Re: Another A55 buildRe: Graham Motzing Graham Motzing 01/27/21 11:50PM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/28/21 12:38AM
  Re: Another A55 buildRe: Graham Motzing Graham Motzing 01/28/21 09:28AM
  Re: Another A55 buildRe: Jay Rivett Jay Rivett 01/28/21 12:27PM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/28/21 12:29PM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/28/21 11:04PM
  Re: Another A55 buildRe: Josh Meyer Josh Meyer 01/26/21 03:41PM
