> Jason ( ͡° ͜ʖ ͡°) Wrote:
> Yeah I suppose this cam/shaft type deal to control both carbs with one
> cable works when they are right next to each other but for carbs in
> totally different locations won't really help.
Doesn't really matter, the cam is just a ratio changer that has one cable in and two cable outputs to mount things wherever you want. Even with dual carb vespas, it's no farther apart than typical carb and oil pump setups that feature the cam.
