Re: Motobecane Stock Variator Tuning: what you need to know
> Alan Jackson wrote:
> lol good idea. or how about clear tubing stuck to the outside so you
> could see it in action? would that actually help balance it or would
> the lead just get flung randomly all over the place?
Yes , it would help balance . Just like balance beads/BBs in a tire , the shot would find the proper place for balance .
Not sure if there's room on the outside of the bell and how would it be kept in place ?
Alan Jackson /
anyone trying this mod DO NOT attach the springs as in the last pic. the spring actually pulls the leafs back onto themselves so the middle is curved up. a bit like curving a playing card in your hand. the more you squeeze the more curved upwards it bends. as i tried stronger springs the penny soon dropped when i couldnt even fit the drum back on because the middles of the leafs were forced out too much.
Alan Jackson /
this is the angle the springs need to be if using more than 2 springs. the angle of the tension keeps the leaves from bending upwards in the middle. 6k rpm engagement or stall has been acheived.
luckily i didnt have to re weld anything. i just moved the anchor point of the spring like so. ill post a video at the weekend as its now dark when i get home from work.
Alan Jackson /
got it engaging at roughly 5 k. 0-30 in 50 metres. i'd like 6k so a bit more tweaking to be done yet. but it seems reliable or regular and constant.
