Re: Motobecane Stock Variator Tuning: what you need to know
weldwizard Jake /
Put the clutch drum in the lathe to remove some more material and hopefully balance it a bit. Then I media blasted just to even out the look. If I was worried about it rusting or longevity I would give it a quick squirt of paint, but fuck it, shitty race bike. A lil surface rust won't matter.
I initially installed the lightest Treats Jammer springs, wasnt even close. Then the heaviest Jammer springs, definitely needed more. Then jumped wayyy up to the red springs from the 2911326 Malossi set.
Daaaaaaaamn! Super dope.
With all the holes drilled and taken down a bit on the lathe, the clutch drum with springs and pads installed weighs 445 grams, just under 1lb.
  Motobecane Stock Variator Tuning: what you need to knowTopic by: Toledo Riot Toledo Riot 11/23/20 10:34AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Rebel Moby Rebel Moby 11/23/20 12:21PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/23/20 12:26PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/23/20 12:31PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Toledo Riot Toledo Riot 11/23/20 12:55PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/23/20 12:58PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/23/20 01:05PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Graham Motzing Graham Motzing 11/23/20 04:23PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Toledo Riot Toledo Riot 11/23/20 04:58PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Graham Motzing Graham Motzing 11/24/20 12:01AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: EH FCC of the QCB EH FCC of the QCB 11/23/20 07:13PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: niklaus _ niklaus _ 11/23/20 11:58PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: weldwizard Jake weldwizard Jake 11/24/20 12:54AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Toledo Riot Toledo Riot 11/24/20 12:55PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: weldwizard Jake weldwizard Jake 11/24/20 01:34PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: niklaus _ niklaus _ 11/24/20 12:00AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Graham Motzing Graham Motzing 11/24/20 12:04AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: niklaus _ niklaus _ 11/24/20 02:36AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: weldwizard Jake weldwizard Jake 11/24/20 12:40AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Graham Motzing Graham Motzing 11/24/20 08:38AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: 666 420 666 420 11/24/20 01:36AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/24/20 02:41AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: niklaus _ niklaus _ 11/24/20 03:02AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: niklaus _ niklaus _ 11/24/20 03:03AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: 666 420 666 420 11/24/20 03:13AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Toledo Riot Toledo Riot 11/24/20 01:52PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/24/20 04:42PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: weldwizard Jake weldwizard Jake 11/24/20 11:04PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: weldwizard Jake weldwizard Jake 11/24/20 11:22PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/24/20 10:35AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Graham Motzing Graham Motzing 11/24/20 01:33PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/24/20 11:50PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Graham Motzing Graham Motzing 11/25/20 08:52AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/25/20 11:44AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Graham Motzing Graham Motzing 11/26/20 12:15PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/26/20 05:58PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/26/20 06:18PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/26/20 09:01PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/26/20 09:10PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/27/20 11:46AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/27/20 12:28PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Graham Motzing Graham Motzing 11/27/20 01:34PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/27/20 01:59PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/27/20 05:12PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/27/20 05:18PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Daniel '' Daniel '' 11/29/20 01:05PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: weldwizard Jake weldwizard Jake 11/29/20 04:23PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/29/20 09:12PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: weldwizard Jake weldwizard Jake 11/29/20 10:33PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: weldwizard Jake weldwizard Jake 11/29/20 10:55PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: weldwizard Jake weldwizard Jake 11/29/20 11:09PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/30/20 09:08PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/30/20 09:11PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: weldwizard Jake weldwizard Jake 12/01/20 10:15AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: weldwizard Jake weldwizard Jake 12/01/20 10:32AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Toledo Riot Toledo Riot 12/01/20 12:46PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 12/01/20 01:14PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: weldwizard Jake weldwizard Jake 12/01/20 01:32PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 12/01/20 01:37PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 12/01/20 01:53PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: weldwizard Jake weldwizard Jake 12/01/20 10:22PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 12/02/20 01:39AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Graham Motzing Graham Motzing 12/02/20 11:10AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: EH FCC of the QCB EH FCC of the QCB 12/02/20 06:33PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/27/20 10:05PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Toledo Riot Toledo Riot 11/25/20 01:53PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/25/20 09:17PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/25/20 09:19PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/25/20 09:24PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: weldwizard Jake weldwizard Jake 11/26/20 12:12AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: weldwizard Jake weldwizard Jake 11/26/20 12:21AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/26/20 12:36AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: weldwizard Jake weldwizard Jake 11/26/20 01:04AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/26/20 11:38AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: weldwizard Jake weldwizard Jake 11/26/20 07:08PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Toledo Riot Toledo Riot 11/28/20 10:08AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Rebel Moby Rebel Moby 11/28/20 07:56PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: EH FCC of the QCB EH FCC of the QCB 11/28/20 09:05PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/28/20 09:37PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 12/02/20 10:14AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Siezed Again Siezed Again 12/02/20 08:50PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Toledo Riot Toledo Riot 12/03/20 02:34PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 12/03/20 02:56PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Siezed Again Siezed Again 12/02/20 09:34PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Graham Motzing Graham Motzing 12/02/20 10:18PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Siezed Again Siezed Again 12/03/20 12:04PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Graham Motzing Graham Motzing 12/03/20 02:47PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: b to the eff b to the eff 12/03/20 04:10PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 12/03/20 07:51PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 12/03/20 08:43PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 12/03/20 11:00PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 12/04/20 11:42AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Graham Motzing Graham Motzing 12/04/20 03:48PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 12/04/20 09:13PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 12/04/20 10:19PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 12/05/20 05:23PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 12/05/20 06:08PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 12/09/20 09:47PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Rebel Moby Rebel Moby 12/10/20 10:36AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Toledo Riot Toledo Riot 12/04/20 04:35PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Toledo Riot Toledo Riot 12/10/20 03:40PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Graham Motzing Graham Motzing 12/10/20 05:34PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 12/10/20 08:04PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 12/10/20 09:36PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Alan Jackson Alan Jackson 08/30/21 09:04AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Alan Jackson Alan Jackson 08/30/21 11:24AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Toledo Riot Toledo Riot 08/31/21 01:37PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Alan Jackson Alan Jackson 09/21/21 08:55AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: pat splat pat splat 09/23/21 12:14AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Graham Motzing Graham Motzing 09/23/21 09:04AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: pat splat pat splat 09/29/21 12:37AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Toledo Riot Toledo Riot 09/29/21 10:50AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Alan Jackson Alan Jackson 10/29/21 06:29PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Alan Jackson Alan Jackson 10/30/21 02:18PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Graham Motzing Graham Motzing 10/30/21 07:44PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Alan Jackson Alan Jackson 10/31/21 05:30AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: b to the eff b to the eff 10/30/21 09:34PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: b to the eff b to the eff 10/31/21 01:12PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: P D P D 10/31/21 02:19PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Alan Jackson Alan Jackson 11/06/21 01:39AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: P D P D 11/06/21 09:34AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Alan Jackson Alan Jackson 11/10/21 04:50PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Alan Jackson Alan Jackson 11/10/21 04:54PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Alan Jackson Alan Jackson 11/14/21 08:57AM
