So for lightening this clutch,
Does a cut off torch warp shit really bad or not?
That would make quick work of making this clutch much lighter pre balancing
There’s no way I wanna drill holes in this thickass plate. Fuck that
I want to make this clutch like swiss cheese
After I chop it up, I’m planning on doing a fun balancing technique I used to do.
You stuff a rod that’s close to the id of the center, tape it a bit then stuff it in.
Then I have these parallel rails that I roll the setup on. The heavy spot always ends up on the bottom. Then I take away material from that area and roll again. Sometimes it’s obvious, other times it’s harder to find. It would be better with the shaft floating on bearings but this works.
Just takes a lil time.
Anyone have any other good techniques to balance? Is there any small balancing machines out there?
