Re: Motobecane Stock Variator Tuning: what you need to know
Totally normal JBOT /
Right on. I’m going to try that flat clutch plate mod with hobbit shoes or similar tomorrow.....
Or maybe starter shoes, depends what I find.
It’ll be like the idea with the diy clutch pulley nik posted but on the front.
  Motobecane Stock Variator Tuning: what you need to knowTopic by: Toledo Riot Toledo Riot 11/23/20 10:34AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Rebel Moby Rebel Moby 11/23/20 12:21PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/23/20 12:26PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/23/20 12:31PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Toledo Riot Toledo Riot 11/23/20 12:55PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/23/20 12:58PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/23/20 01:05PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Graham Motzing Graham Motzing 11/23/20 04:23PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Toledo Riot Toledo Riot 11/23/20 04:58PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Graham Motzing Graham Motzing 11/24/20 12:01AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 11/23/20 07:13PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: niklaus _ niklaus _ 11/23/20 11:58PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: weldwizard Jake weldwizard Jake 11/24/20 12:54AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Toledo Riot Toledo Riot 11/24/20 12:55PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: weldwizard Jake weldwizard Jake 11/24/20 01:34PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: niklaus _ niklaus _ 11/24/20 12:00AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Graham Motzing Graham Motzing 11/24/20 12:04AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: niklaus _ niklaus _ 11/24/20 02:36AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: weldwizard Jake weldwizard Jake 11/24/20 12:40AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Graham Motzing Graham Motzing 11/24/20 08:38AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: 666 420 666 420 11/24/20 01:36AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/24/20 02:41AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: niklaus _ niklaus _ 11/24/20 03:02AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: niklaus _ niklaus _ 11/24/20 03:03AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: 666 420 666 420 11/24/20 03:13AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Toledo Riot Toledo Riot 11/24/20 01:52PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/24/20 04:42PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: weldwizard Jake weldwizard Jake 11/24/20 11:04PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: weldwizard Jake weldwizard Jake 11/24/20 11:22PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/24/20 10:35AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Graham Motzing Graham Motzing 11/24/20 01:33PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/24/20 11:50PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Graham Motzing Graham Motzing 11/25/20 08:52AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/25/20 11:44AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Graham Motzing Graham Motzing 11/26/20 12:15PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/26/20 05:58PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/26/20 06:18PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/26/20 09:01PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/26/20 09:10PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/27/20 11:46AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/27/20 12:28PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Graham Motzing Graham Motzing 11/27/20 01:34PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/27/20 01:59PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/27/20 05:12PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/27/20 05:18PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Daniel '' Daniel '' 11/29/20 01:05PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: weldwizard Jake weldwizard Jake 11/29/20 04:23PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/29/20 09:12PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: weldwizard Jake weldwizard Jake 11/29/20 10:33PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: weldwizard Jake weldwizard Jake 11/29/20 10:55PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: weldwizard Jake weldwizard Jake 11/29/20 11:09PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/30/20 09:08PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/30/20 09:11PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: weldwizard Jake weldwizard Jake 12/01/20 10:15AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: weldwizard Jake weldwizard Jake 12/01/20 10:32AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Toledo Riot Toledo Riot 12/01/20 12:46PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 12/01/20 01:14PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: weldwizard Jake weldwizard Jake 12/01/20 01:32PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 12/01/20 01:37PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 12/01/20 01:53PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: weldwizard Jake weldwizard Jake 12/01/20 10:22PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 12/02/20 01:39AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Graham Motzing Graham Motzing 12/02/20 11:10AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 12/02/20 06:33PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/27/20 10:05PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Toledo Riot Toledo Riot 11/25/20 01:53PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/25/20 09:17PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/25/20 09:19PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/25/20 09:24PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: weldwizard Jake weldwizard Jake 11/26/20 12:12AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: weldwizard Jake weldwizard Jake 11/26/20 12:21AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/26/20 12:36AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: weldwizard Jake weldwizard Jake 11/26/20 01:04AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/26/20 11:38AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: weldwizard Jake weldwizard Jake 11/26/20 07:08PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Toledo Riot Toledo Riot 11/28/20 10:08AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Rebel Moby Rebel Moby 11/28/20 07:56PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 11/28/20 09:05PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 11/28/20 09:37PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 12/02/20 10:14AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Siezed Again Siezed Again 12/02/20 08:50PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Toledo Riot Toledo Riot 12/03/20 02:34PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 12/03/20 02:56PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Siezed Again Siezed Again 12/02/20 09:34PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Graham Motzing Graham Motzing 12/02/20 10:18PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Siezed Again Siezed Again 12/03/20 12:04PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Graham Motzing Graham Motzing 12/03/20 02:47PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: b to the eff b to the eff 12/03/20 04:10PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 12/03/20 07:51PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 12/03/20 08:43PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 12/03/20 11:00PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 12/04/20 11:42AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Graham Motzing Graham Motzing 12/04/20 03:48PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 12/04/20 09:13PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 12/04/20 10:19PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 12/05/20 05:23PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 12/05/20 06:08PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 12/09/20 09:47PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Rebel Moby Rebel Moby 12/10/20 10:36AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Toledo Riot Toledo Riot 12/04/20 04:35PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Toledo Riot Toledo Riot 12/10/20 03:40PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Graham Motzing Graham Motzing 12/10/20 05:34PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 12/10/20 08:04PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Totally normal JBOT Totally normal JBOT 12/10/20 09:36PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Alan Jackson Alan Jackson 08/30/21 09:04AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Alan Jackson Alan Jackson 08/30/21 11:24AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Toledo Riot Toledo Riot 08/31/21 01:37PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Alan Jackson Alan Jackson 09/21/21 08:55AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: pat splat pat splat 09/23/21 12:14AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Graham Motzing Graham Motzing 09/23/21 09:04AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: pat splat pat splat 09/29/21 12:37AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Toledo Riot Toledo Riot 09/29/21 10:50AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Alan Jackson Alan Jackson 10/29/21 06:29PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Alan Jackson Alan Jackson 10/30/21 02:18PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Graham Motzing Graham Motzing 10/30/21 07:44PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Alan Jackson Alan Jackson 10/31/21 05:30AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: b to the eff b to the eff 10/30/21 09:34PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: b to the eff b to the eff 10/31/21 01:12PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: P D P D 10/31/21 02:19PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Alan Jackson Alan Jackson 11/06/21 01:39AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: P D P D 11/06/21 09:34AM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Alan Jackson Alan Jackson 11/10/21 04:50PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Alan Jackson Alan Jackson 11/10/21 04:54PM
  Re: Motobecane Stock Variator Tuning: what you need to knowRe: Alan Jackson Alan Jackson 11/14/21 08:57AM
