Realized the starter bell has just a pressed in center, so that needs some reinforcement welds if you're going to weld the variator shaft directly to it.
Pressed center.
Stich welded center.
Other side offset stich welded.
Thats all I got done in the limited time I had today. Just need to weld on the variator shaft and the cheek posts to complete the whole starter plate removal.
