So I've got my treats caliper mounted up on EBRs with the treats bracket. They say it should all line up, but I had to add a 3mm spacer (might still need .3 or .4mm more) between the bracket and the forks.
I haven't set a disc brake up from scratch, but as far as I know, the outer pad (without the piston against it) should be as close as possible to the disc without touching at rest, and the piston side pad should push against the rotor and deflect it a tiny bit into the other pad.
As far as I can tell, there's no way I could move that outer pad 3mm away from the rotor and still be able to brake. Might not even fit in the cutaway on the caliper. It's a pretty tight fit on that side as it is:
So, does anyone else run this setup? Did you have to use spacers like this or am I missing something? (edited)
