Don’t know, thermo hasn’t worked for me like ever. I like to push timing if I can so a pump really helps keep it cooler on the long mountains. I’m gonna try that weird ruckus plastic radiator to see how it does.
The 2 speed pulley is leaking like crazy. I think it’s the front axle seal so I gotta figure out what size it is then swap that. Used sealant for the large black covers oring but that’s holding fine.
I gotta chop these pedal arms too. Gonna switch to a legal version of “operable” pedals with like 1-2 inch travel so they won’t hit the ground on turns. Riding with the lever activated antibackup pedal function, I’m always trying to bring one pedal arm side up for turns since this moped is low boiii but it’s not fun to have to prepare the pedal position every turn and pull a lever to backpedal.. I guess I’m used to backpedaling more than front pedaling
Maybe I’ll get better at releasing the lock it but getting your shins smashed at stops from the pedal shaft being totally unlocked is way worse so yeah cool story bro
