Re: CRe: Solo Fuckery
P D /
> JBOT Admin Wrote:
> The solid copper will solve this with some sealant. I saw where the
> gasket blew out. It was just paper. The issue is finding the right
> technique to seal it. If you never swapped out the head gasket to
> something different your idea of some magic amount of fluid is not
> relevant in this situation. The stock gasket was like epoxy it was stuck
> so well. Maybe some thin jb weld or high tack copper spray on top of
> the copper sheet will work. It’ll get figured out
Just for reference :
I had an Isuzu pickup the had a motor with aluminum block and cast head .
It would blow head gaskets because of the different expansions of the two materials .
High Tack was the only thing I found , applied to a stock gasket , that would hold for any length of time .
  Solo FuckeryTopic by: JBOT Admin JBOT Admin 10/17/20 11:32AM
  Re: Solo FuckeryRe: Graham Motzing Graham Motzing 10/17/20 01:22PM
  Re: Solo FuckeryRe: Aaron Goldman Aaron Goldman 10/17/20 01:49PM
  Re: Solo FuckeryRe: EH FCC of the QCB EH FCC of the QCB 10/18/20 03:02PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 10/18/20 03:40PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/18/20 04:41PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 10/18/20 06:23PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/18/20 06:55PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/18/20 06:56PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 10/18/20 11:19PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/18/20 11:25PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/18/20 11:34PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 10/19/20 02:01AM
  Re: Solo FuckeryRe: Graham Motzing Graham Motzing 10/18/20 07:20PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/18/20 08:42PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/17/20 02:02PM
  Re: Solo FuckeryRe: Graham Motzing Graham Motzing 10/17/20 09:47PM
  Re: Solo FuckeryRe: Graham Motzing Graham Motzing 10/17/20 09:49PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/17/20 10:36PM
  Re: Solo FuckeryRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 10/18/20 03:34PM
  Re: Solo FuckeryRe: Mitch Mills Mitch Mills 10/18/20 05:01PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/18/20 05:33PM
  Re: Solo FuckeryRe: Chris Squid Chris Squid 10/18/20 05:40PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/18/20 06:01PM
  Re: Solo FuckeryRe: Mitch Mills Mitch Mills 10/18/20 07:27PM
  Re: Solo FuckeryRe: Mitch Mills Mitch Mills 10/19/20 09:27AM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 10/19/20 12:06PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/19/20 08:41PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/19/20 09:08PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/19/20 10:17PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/19/20 10:19PM
  Re: Solo FuckeryRe: Aaron Blair Aaron Blair 10/19/20 09:58AM
  Re: Solo FuckeryRe: Toledo Riot Toledo Riot 10/19/20 11:10AM
  Re: Solo FuckeryRe: Graham Motzing Graham Motzing 10/19/20 10:50PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/19/20 11:54PM
  Re: Solo FuckeryRe: Graham Motzing Graham Motzing 10/21/20 03:35PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/21/20 07:01PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/21/20 07:43PM
  Re: Solo FuckeryRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 10/21/20 11:15PM
  Re: Solo FuckeryRe: Born to be WillD Born to be WillD 11/03/20 05:04PM
  Re: Solo FuckeryRe: classic carl jepsen classic carl jepsen 11/05/20 02:47PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/05/20 05:19PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/05/20 07:28PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/05/20 09:30PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 11/06/20 01:22AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/06/20 01:48AM
  Re: Solo FuckeryRe: - Joe - - Joe - 11/06/20 08:06AM
  Re: Solo FuckeryRe: Happy Pancake Happy Pancake 11/12/20 10:18PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/12/20 11:04PM
  Re: Solo FuckeryRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 10/20/20 09:44AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/20/20 11:02AM
  Re: Solo FuckeryRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 10/20/20 11:23AM
  Re: Solo FuckeryRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 10/20/20 11:26AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/20/20 11:44AM
  Re: Solo FuckeryRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 10/20/20 12:58PM
  Re: Solo FuckeryRe: Born to be WillD Born to be WillD 10/20/20 01:15PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/20/20 01:19PM
  Re: Solo FuckeryRe: Toledo Riot Toledo Riot 10/20/20 02:41PM
  Re: Solo FuckeryRe: Aaron Goldman Aaron Goldman 10/20/20 02:42PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/20/20 02:47PM
  Re: Solo FuckeryRe: Born to be WillD Born to be WillD 10/20/20 04:53PM
  Re: Solo FuckeryRe: P D P D 10/20/20 05:50PM
  Re: Solo FuckeryRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 10/22/20 08:51AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/22/20 01:25PM
  Re: Solo FuckeryRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 10/22/20 04:02PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 10/22/20 10:53PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/22/20 11:50PM
  Re: Solo FuckeryRe: Jeremy Homser Jeremy Homser 10/23/20 11:35AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/23/20 01:02PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/31/20 09:01PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/31/20 09:07PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 10/31/20 09:41PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/31/20 10:00PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/31/20 10:08PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/01/20 10:36PM
  Re: Solo FuckeryRe: P D P D 11/02/20 11:05AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/02/20 11:31AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/02/20 02:30PM
  Re: Solo FuckeryRe: P D P D 11/02/20 04:19PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/02/20 05:19PM
  Re: Solo FuckeryRe: Graham Motzing Graham Motzing 11/02/20 06:46PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/02/20 08:40PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/02/20 08:53PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/03/20 04:33PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 11/03/20 04:54PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/03/20 06:27PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/03/20 07:54PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/04/20 09:18PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 11/05/20 01:56PM
  Re: Solo FuckeryRe: Toledo Riot Toledo Riot 11/05/20 01:40PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/05/20 02:09PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/05/20 02:13PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 11/06/20 10:56AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/07/20 10:55AM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 11/07/20 04:36PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/07/20 08:35PM
  Re: Solo FuckeryRe: todd amundson todd amundson 11/07/20 11:39PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/08/20 03:00PM
  Re: Solo FuckeryRe: Jackerz ! Jackerz ! 11/09/20 06:27AM
  Re: Solo FuckeryRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 11/09/20 07:19AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/09/20 12:36PM
  Re: Solo FuckeryRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 11/09/20 12:16AM
  Re: Solo FuckeryRe: cheetahchrome . cheetahchrome . 11/10/20 09:59AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/10/20 11:22AM
  Re: Solo FuckeryRe: cheetahchrome . cheetahchrome . 11/11/20 08:37AM
  Re: Solo FuckeryRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 11/11/20 09:48AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/12/20 09:45PM
  Re: Solo FuckeryRe: EH FCC of the QCB EH FCC of the QCB 11/13/20 11:40AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/13/20 01:47PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 11/13/20 01:56PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/13/20 02:08PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 11/13/20 02:12PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/13/20 02:27PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 11/13/20 02:53PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/13/20 04:36PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/22/20 09:10PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/22/20 09:14PM
  Re: Solo FuckeryRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 11/27/20 09:06PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/27/20 09:40PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 11/28/20 09:03PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/28/20 09:38PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/03/20 12:43AM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 12/03/20 02:30PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/03/20 02:57PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/16/20 10:33PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 12/17/20 12:29AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/17/20 10:16AM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 12/17/20 11:40AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/17/20 12:15PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/17/20 09:46PM
  Re: Solo FuckeryRe: Thomas Peffer Thomas Peffer 12/17/20 09:53PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/17/20 09:55PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/17/20 10:26PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/13/20 02:39PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/13/20 02:46PM
  Re: Solo FuckeryRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 11/13/20 12:13PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/23/20 09:18PM
  Re: Solo FuckeryRe: LSLB RXb LSLB RXb 11/24/20 12:33PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 11/24/20 12:38PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/24/20 12:46PM
  Re: Solo FuckeryRe: EH FCC of the QCB EH FCC of the QCB 11/27/20 06:42PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/27/20 07:04PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/24/20 12:44PM
  Re: Solo FuckeryRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 11/28/20 12:17AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/28/20 12:41AM
  Re: Solo FuckeryRe: Aaron Blair Aaron Blair 11/28/20 02:39AM
  Re: Solo FuckeryRe: Mitch Mills Mitch Mills 11/28/20 09:39AM
  Re: Solo FuckeryRe: Aaron Blair Aaron Blair 11/28/20 11:42AM
  Re: Solo FuckerydRe: JBOT Admin JBOT Admin 11/28/20 04:55PM
  Re: Solo FuckeryRe: EH FCC of the QCB EH FCC of the QCB 12/17/20 10:50PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/18/20 09:13PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 12/19/20 12:41AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/19/20 09:09PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/19/20 09:12PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/19/20 09:17PM
  Re: Solo FuckeryRe: EH FCC of the QCB EH FCC of the QCB 12/20/20 09:31AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/20/20 10:13AM
  Re: Solo FuckeryRe: EH FCC of the QCB EH FCC of the QCB 12/20/20 11:41AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/20/20 12:07PM
  Re: Solo FuckeryRe: EH FCC of the QCB EH FCC of the QCB 12/20/20 12:17PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/20/20 12:20PM
  Re: Solo FuckeryRe: EH FCC of the QCB EH FCC of the QCB 12/20/20 12:22PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/20/20 12:22PM
  Re: Solo FuckeryRe: EH FCC of the QCB EH FCC of the QCB 12/20/20 12:23PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 12/20/20 04:02PM
  Re: Solo FuckeryRe: Mitch Mills Mitch Mills 12/20/20 05:45PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/20/20 10:54PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/26/20 09:31PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 12/27/20 12:37AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/27/20 08:27PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/27/20 08:29PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/27/20 08:57PM
  Re: Solo FuckeryRe: * wormdirt * * wormdirt * 12/27/20 08:47PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/27/20 09:01PM
  Re: Solo FuckeryRe: * wormdirt * * wormdirt * 12/27/20 11:05PM
  Re: Solo FuckeryRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 12/28/20 07:48AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/28/20 12:07PM
  Re: Solo FuckeryRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 12/28/20 12:39PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/28/20 08:26PM
  Re: Solo FuckeryRe: Jeremy Homser Jeremy Homser 01/02/21 01:07AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/02/21 08:17PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 01/03/21 11:40AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/03/21 11:51AM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 01/03/21 03:43PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/03/21 09:16PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 01/03/21 09:36PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/03/21 10:12PM
  Re: Solo FuckeryRe: Graham Motzing Graham Motzing 01/03/21 09:52PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 01/03/21 10:58PM
  Re: Solo FuckeryRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 01/03/21 11:19PM
  Re: Solo FuckeryRe: Brandon Love Brandon Love 12/19/20 09:53PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/19/20 10:07PM
  Re: Solo FuckeryRe: Mitch Mills Mitch Mills 12/20/20 10:48AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/20/20 10:54AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/28/20 08:52PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/29/20 07:12PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/01/21 10:34AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/01/21 02:52PM
  Re: Solo FuckeryRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 01/04/21 09:33AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/04/21 11:08AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/04/21 11:42AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/04/21 07:32PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/07/21 09:26PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/07/21 09:46PM
  Re: Solo FuckeryRe: EH FCC of the QCB EH FCC of the QCB 01/07/21 10:59PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/07/21 11:33PM
  Re: Solo FuckeryRe: EH FCC of the QCB EH FCC of the QCB 01/07/21 11:48PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/08/21 12:27AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/08/21 01:04AM
  Re: Solo FuckeryRe: Mitch Mills Mitch Mills 01/08/21 01:18PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/08/21 01:22PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 01/08/21 06:17PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/08/21 09:05PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/08/21 09:13PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/08/21 09:18PM
  Re: Solo FuckeryRe: EH FCC of the QCB EH FCC of the QCB 01/08/21 09:59PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/09/21 06:01PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/09/21 08:56PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/17/21 07:06PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/18/21 09:25PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/18/21 09:32PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/18/21 09:36PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/19/21 09:14PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/29/21 05:49PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/31/21 06:51PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 02/01/21 10:44PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 02/02/21 09:51PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 02/03/21 05:42PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 02/03/21 06:14PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 02/03/21 09:10PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 02/05/21 12:58PM
  Re: Solo FuckeryRe: Tweaker trash Tweaker trash 03/01/21 10:30AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 03/01/21 11:12AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 03/17/21 07:55PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 03/17/21 08:28PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 02/05/21 05:25PM
  Re: Solo FuckeryRe: Mitch Mills Mitch Mills 02/05/21 07:14PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 02/05/21 09:36PM
  CRe: Solo FuckeryRe: JBOT Admin JBOT Admin 02/10/21 05:44PM
  Re: CRe: Solo FuckeryRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 02/11/21 01:55AM
  Re: CRe: Solo FuckeryRe: JBOT Admin JBOT Admin 02/11/21 02:18AM
  Re: CRe: Solo FuckeryRe: JBOT Admin JBOT Admin 02/11/21 02:23AM
  Re: CRe: Solo FuckeryRe: P D P D 02/11/21 10:12AM
  Re: CRe: Solo FuckeryRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 02/11/21 02:28AM
  Re: CRe: Solo FuckeryRe: JBOT Admin JBOT Admin 02/11/21 02:36AM
  Re: CRe: Solo FuckeryRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 02/11/21 11:49AM
  Re: CRe: Solo FuckeryRe: JBOT Admin JBOT Admin 02/11/21 12:52PM
  Re: CRe: Solo FuckeryRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 02/11/21 01:30PM
  Re: Solo FuckeryRe: Mitch Mills Mitch Mills 02/10/21 06:53PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 02/10/21 08:18PM
  Re: Solo FuckeryRe: Graham Motzing Graham Motzing 02/10/21 08:36PM
  Re: Solo FuckeryRe: P D P D 02/10/21 09:20PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 02/10/21 09:33PM
  Re: Solo FuckeryRe: P D P D 02/10/21 10:09PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 02/11/21 03:00AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 02/11/21 03:02AM
  Re: Solo FuckeryRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 02/11/21 03:38AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 02/11/21 02:16PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 02/11/21 08:20PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 02/11/21 08:51PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 02/11/21 09:35PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 02/12/21 09:24PM
  Re: Solo FuckeryRe: Jay Rivett Jay Rivett 02/14/21 11:24AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 02/14/21 01:23PM
  Re: Solo FuckeryRe: Jay Rivett Jay Rivett 02/15/21 10:24AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 02/15/21 11:09AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 02/16/21 09:39PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 02/16/21 09:44PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 02/17/21 12:23AM
  Re: Solo FuckeryRe: Joel P Joel P 02/17/21 07:31AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 02/17/21 12:23PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 02/17/21 06:21PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 02/17/21 07:07PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 02/17/21 07:08PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 02/17/21 08:40PM
  Re: Solo FuckeryRe: * wormdirt * * wormdirt * 02/18/21 12:30AM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 02/18/21 02:32PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 02/18/21 03:43PM
  Re: Solo FuckeryRe: Aaron Blair Aaron Blair 02/17/21 10:55AM
  Re: Solo FuckeryRe: L e e L e e 02/17/21 08:49PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 02/17/21 08:52PM
  Re: Solo FuckeryRe: L e e L e e 02/17/21 08:59PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 02/17/21 09:04PM
  Re: Solo FuckeryRe: Graham Motzing Graham Motzing 02/18/21 04:36PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 02/26/21 01:36PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 02/27/21 10:05PM
  Re: Solo FuckeryRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 02/27/21 10:09PM
  Re: Solo FuckeryRe: Graham Motzing Graham Motzing 02/17/21 09:27PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 02/17/21 09:48PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 02/17/21 09:55PM
  Re: Solo FuckeryRe: L e e L e e 02/17/21 11:14PM
  Re: Solo FuckeryRe: Rubble Raiser Rubble Raiser 02/18/21 02:02AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 02/18/21 02:20AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 02/18/21 01:55PM
  Re: Solo FuckeryRe: Mitch Mills Mitch Mills 03/18/21 10:49AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 03/20/21 11:00PM
  Re: Solo FuckeryRe: * wormdirt * * wormdirt * 03/20/21 11:12PM
  Re: Solo FuckeryRe: P D P D 03/21/21 10:42AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 03/21/21 12:17PM
  Re: Solo FuckeryRe: Eric Whatley Eric Whatley 04/04/21 07:07PM
  Re: Solo FuckeryRe: Jay Rivett Jay Rivett 04/04/21 07:52PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 04/04/21 07:59PM
  Re: Solo FuckeryRe: Eric Whatley Eric Whatley 04/13/21 02:47PM
