Re: Solo Fuckery
Born to be WillD /
The physics are pretty basic when it comes to heat transfer, pretty much any time you have any interface you lose a lot of heat transfer. It's significantly worse than just solid aluminum, like theoretically orders of magnitude, to the point I would expect it probably sheds more heat through the metal-metal contact points than thru the water.
The only ways liquid cooling works are
1) Moving heat. water's got good heat capacity, and transfers heat better into it. Like metal to liquid is better than metal to air. Then you can pump or siphon the hot water to an efficient radiator, and pump it back in. It's just moving the heat via water to a better cooler.
2) absorbing energy. Water does have a high heat capacity so it'll soak up more energy to heat it up, like a big heat sink. Doubt that'd really get you far tho. Or much more so it cools stuff by taking a BUNCH of energy to evaporate. so evaporative cooling can keep stuff super cool, but only if it's allowed to evaporate. But that'd require pretty regular refills.
So on the solo, if it's not moving the hot water to an efficient radiator and replacing with cooler water, and if it's not evaporating the water, then the water jacket is just impeding heat transfer outta the cylinder. It's like a jacket, an insulating layer. Cuz your heat loss is all off the outer fins anyway, it's just got a more convoluted path to get there
  Solo FuckeryTopic by: JBOT Admin JBOT Admin 10/17/20 11:32AM
  Re: Solo FuckeryRe: Graham Motzing Graham Motzing 10/17/20 01:22PM
  Re: Solo FuckeryRe: Aaron Goldman Aaron Goldman 10/17/20 01:49PM
  Re: Solo FuckeryRe: EH FCC of the QCB EH FCC of the QCB 10/18/20 03:02PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 10/18/20 03:40PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/18/20 04:41PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 10/18/20 06:23PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/18/20 06:55PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/18/20 06:56PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 10/18/20 11:19PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/18/20 11:25PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/18/20 11:34PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 10/19/20 02:01AM
  Re: Solo FuckeryRe: Graham Motzing Graham Motzing 10/18/20 07:20PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/18/20 08:42PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/17/20 02:02PM
  Re: Solo FuckeryRe: Graham Motzing Graham Motzing 10/17/20 09:47PM
  Re: Solo FuckeryRe: Graham Motzing Graham Motzing 10/17/20 09:49PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/17/20 10:36PM
  Re: Solo FuckeryRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 10/18/20 03:34PM
  Re: Solo FuckeryRe: Mitch Mills Mitch Mills 10/18/20 05:01PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/18/20 05:33PM
  Re: Solo FuckeryRe: Chris Squid Chris Squid 10/18/20 05:40PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/18/20 06:01PM
  Re: Solo FuckeryRe: Mitch Mills Mitch Mills 10/18/20 07:27PM
  Re: Solo FuckeryRe: Mitch Mills Mitch Mills 10/19/20 09:27AM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 10/19/20 12:06PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/19/20 08:41PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/19/20 09:08PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/19/20 10:17PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/19/20 10:19PM
  Re: Solo FuckeryRe: Aaron Blair Aaron Blair 10/19/20 09:58AM
  Re: Solo FuckeryRe: Toledo Riot Toledo Riot 10/19/20 11:10AM
  Re: Solo FuckeryRe: Graham Motzing Graham Motzing 10/19/20 10:50PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/19/20 11:54PM
  Re: Solo FuckeryRe: Graham Motzing Graham Motzing 10/21/20 03:35PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/21/20 07:01PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/21/20 07:43PM
  Re: Solo FuckeryRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 10/21/20 11:15PM
  Re: Solo FuckeryRe: Born to be WillD Born to be WillD 11/03/20 05:04PM
  Re: Solo FuckeryRe: classic carl jepsen classic carl jepsen 11/05/20 02:47PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/05/20 05:19PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/05/20 07:28PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/05/20 09:30PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 11/06/20 01:22AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/06/20 01:48AM
  Re: Solo FuckeryRe: - Joe - - Joe - 11/06/20 08:06AM
  Re: Solo FuckeryRe: Happy Pancake Happy Pancake 11/12/20 10:18PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/12/20 11:04PM
  Re: Solo FuckeryRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 10/20/20 09:44AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/20/20 11:02AM
  Re: Solo FuckeryRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 10/20/20 11:23AM
  Re: Solo FuckeryRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 10/20/20 11:26AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/20/20 11:44AM
  Re: Solo FuckeryRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 10/20/20 12:58PM
  Re: Solo FuckeryRe: Born to be WillD Born to be WillD 10/20/20 01:15PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/20/20 01:19PM
  Re: Solo FuckeryRe: Toledo Riot Toledo Riot 10/20/20 02:41PM
  Re: Solo FuckeryRe: Aaron Goldman Aaron Goldman 10/20/20 02:42PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/20/20 02:47PM
  Re: Solo FuckeryRe: Born to be WillD Born to be WillD 10/20/20 04:53PM
  Re: Solo FuckeryRe: P D P D 10/20/20 05:50PM
  Re: Solo FuckeryRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 10/22/20 08:51AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/22/20 01:25PM
  Re: Solo FuckeryRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 10/22/20 04:02PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 10/22/20 10:53PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/22/20 11:50PM
  Re: Solo FuckeryRe: Jeremy Homser Jeremy Homser 10/23/20 11:35AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/23/20 01:02PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/31/20 09:01PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/31/20 09:07PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 10/31/20 09:41PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/31/20 10:00PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 10/31/20 10:08PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/01/20 10:36PM
  Re: Solo FuckeryRe: P D P D 11/02/20 11:05AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/02/20 11:31AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/02/20 02:30PM
  Re: Solo FuckeryRe: P D P D 11/02/20 04:19PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/02/20 05:19PM
  Re: Solo FuckeryRe: Graham Motzing Graham Motzing 11/02/20 06:46PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/02/20 08:40PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/02/20 08:53PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/03/20 04:33PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 11/03/20 04:54PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/03/20 06:27PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/03/20 07:54PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/04/20 09:18PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 11/05/20 01:56PM
  Re: Solo FuckeryRe: Toledo Riot Toledo Riot 11/05/20 01:40PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/05/20 02:09PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/05/20 02:13PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 11/06/20 10:56AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/07/20 10:55AM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 11/07/20 04:36PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/07/20 08:35PM
  Re: Solo FuckeryRe: todd amundson todd amundson 11/07/20 11:39PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/08/20 03:00PM
  Re: Solo FuckeryRe: Jackerz ! Jackerz ! 11/09/20 06:27AM
  Re: Solo FuckeryRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 11/09/20 07:19AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/09/20 12:36PM
  Re: Solo FuckeryRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 11/09/20 12:16AM
  Re: Solo FuckeryRe: cheetahchrome . cheetahchrome . 11/10/20 09:59AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/10/20 11:22AM
  Re: Solo FuckeryRe: cheetahchrome . cheetahchrome . 11/11/20 08:37AM
  Re: Solo FuckeryRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 11/11/20 09:48AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/12/20 09:45PM
  Re: Solo FuckeryRe: EH FCC of the QCB EH FCC of the QCB 11/13/20 11:40AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/13/20 01:47PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 11/13/20 01:56PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/13/20 02:08PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 11/13/20 02:12PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/13/20 02:27PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 11/13/20 02:53PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/13/20 04:36PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/22/20 09:10PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/22/20 09:14PM
  Re: Solo FuckeryRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 11/27/20 09:06PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/27/20 09:40PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 11/28/20 09:03PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/28/20 09:38PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/03/20 12:43AM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 12/03/20 02:30PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/03/20 02:57PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/16/20 10:33PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 12/17/20 12:29AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/17/20 10:16AM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 12/17/20 11:40AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/17/20 12:15PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/17/20 09:46PM
  Re: Solo FuckeryRe: Thomas Peffer Thomas Peffer 12/17/20 09:53PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/17/20 09:55PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/17/20 10:26PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/13/20 02:39PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/13/20 02:46PM
  Re: Solo FuckeryRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 11/13/20 12:13PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/23/20 09:18PM
  Re: Solo FuckeryRe: LSLB RXb LSLB RXb 11/24/20 12:33PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 11/24/20 12:38PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/24/20 12:46PM
  Re: Solo FuckeryRe: EH FCC of the QCB EH FCC of the QCB 11/27/20 06:42PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/27/20 07:04PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/24/20 12:44PM
  Re: Solo FuckeryRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 11/28/20 12:17AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 11/28/20 12:41AM
  Re: Solo FuckeryRe: Aaron Blair Aaron Blair 11/28/20 02:39AM
  Re: Solo FuckeryRe: Mitch Mills Mitch Mills 11/28/20 09:39AM
  Re: Solo FuckeryRe: Aaron Blair Aaron Blair 11/28/20 11:42AM
  Re: Solo FuckerydRe: JBOT Admin JBOT Admin 11/28/20 04:55PM
  Re: Solo FuckeryRe: EH FCC of the QCB EH FCC of the QCB 12/17/20 10:50PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/18/20 09:13PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 12/19/20 12:41AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/19/20 09:09PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/19/20 09:12PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/19/20 09:17PM
  Re: Solo FuckeryRe: EH FCC of the QCB EH FCC of the QCB 12/20/20 09:31AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/20/20 10:13AM
  Re: Solo FuckeryRe: EH FCC of the QCB EH FCC of the QCB 12/20/20 11:41AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/20/20 12:07PM
  Re: Solo FuckeryRe: EH FCC of the QCB EH FCC of the QCB 12/20/20 12:17PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/20/20 12:20PM
  Re: Solo FuckeryRe: EH FCC of the QCB EH FCC of the QCB 12/20/20 12:22PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/20/20 12:22PM
  Re: Solo FuckeryRe: EH FCC of the QCB EH FCC of the QCB 12/20/20 12:23PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 12/20/20 04:02PM
  Re: Solo FuckeryRe: Mitch Mills Mitch Mills 12/20/20 05:45PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/20/20 10:54PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/26/20 09:31PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 12/27/20 12:37AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/27/20 08:27PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/27/20 08:29PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/27/20 08:57PM
  Re: Solo FuckeryRe: * wormdirt * * wormdirt * 12/27/20 08:47PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/27/20 09:01PM
  Re: Solo FuckeryRe: * wormdirt * * wormdirt * 12/27/20 11:05PM
  Re: Solo FuckeryRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 12/28/20 07:48AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/28/20 12:07PM
  Re: Solo FuckeryRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 12/28/20 12:39PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/28/20 08:26PM
  Re: Solo FuckeryRe: Jeremy Homser Jeremy Homser 01/02/21 01:07AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/02/21 08:17PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 01/03/21 11:40AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/03/21 11:51AM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 01/03/21 03:43PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/03/21 09:16PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 01/03/21 09:36PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/03/21 10:12PM
  Re: Solo FuckeryRe: Graham Motzing Graham Motzing 01/03/21 09:52PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 01/03/21 10:58PM
  Re: Solo FuckeryRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 01/03/21 11:19PM
  Re: Solo FuckeryRe: Brandon Love Brandon Love 12/19/20 09:53PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/19/20 10:07PM
  Re: Solo FuckeryRe: Mitch Mills Mitch Mills 12/20/20 10:48AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/20/20 10:54AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/28/20 08:52PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 12/29/20 07:12PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/01/21 10:34AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/01/21 02:52PM
  Re: Solo FuckeryRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 01/04/21 09:33AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/04/21 11:08AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/04/21 11:42AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/04/21 07:32PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/07/21 09:26PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/07/21 09:46PM
  Re: Solo FuckeryRe: EH FCC of the QCB EH FCC of the QCB 01/07/21 10:59PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/07/21 11:33PM
  Re: Solo FuckeryRe: EH FCC of the QCB EH FCC of the QCB 01/07/21 11:48PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/08/21 12:27AM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/08/21 01:04AM
  Re: Solo FuckeryRe: Mitch Mills Mitch Mills 01/08/21 01:18PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/08/21 01:22PM
  Re: Solo FuckeryRe: Daniel '' Daniel '' 01/08/21 06:17PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/08/21 09:05PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/08/21 09:13PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/08/21 09:18PM
  Re: Solo FuckeryRe: EH FCC of the QCB EH FCC of the QCB 01/08/21 09:59PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/09/21 06:01PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/09/21 08:56PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/17/21 07:06PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/18/21 09:25PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/18/21 09:32PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/18/21 09:36PM
  Re: Solo FuckeryRe: JBOT Admin JBOT Admin 01/19/21 09:14PM
