Re: Electronic sequence shifter?
✨KARL✨RAY ✨JEBSON✨ /
With the PatBox It is like moving in two dimensions instead of the one (along the "rpm vs revs" line) of the conventional CVT. Quote from the http://www.pattakon.com/pattakonPatBox.htm : Strengthening (or weakening) the restoring force that acts on the blue lever (by shifting the anchoring end of the restoring spring of the blue lever, for instance), the characteristic curve of the CVT varies: in order to increase the effective diameter of the drive pulley, the variator has to compress (by means of the V-belt) the spring of the driven pulley as usual, but it has also to displace angularly the lever 7 overcoming a stronger (or weaker) restoring force. It is like replacing "on the fly" the rollers of the variator by lighter or heavier ones. In a two-mode version the rider shifts from the "touring" to the "sport" mode by pushing a pin (a button) to anchor a middle point of the blue lever restoring spring: the restoring spring becomes stiffer, a stronger restoring force acts on the blue lever and the variator keeps the revs higher. Thanks Manolis Pattakos
  Electronic sequence shifter?Topic by: Bas Autowas Bas Autowas 10/16/20 07:57AM
  Re: Electronic sequence shifter?Re: P D P D 10/16/20 08:47AM
  Re: Electronic sequence shifter?Re: Dirty30 Dillon Dirty30 Dillon 10/16/20 09:32AM
  Re: Electronic sequence shifter?Re: Beach Club Nick Beach Club Nick 10/16/20 11:48AM
  Re: Electronic sequence shifter?Re: Totally normal JBOT Totally normal JBOT 10/16/20 12:16PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 11/23/20 02:14AM
  Re: Electronic sequence shifter?Re: Totally normal JBOT Totally normal JBOT 11/23/20 11:32AM
  Re: Electronic sequence shifter?Re: Born to be WillD Born to be WillD 10/16/20 03:10PM
  Re: Electronic sequence shifter?Re: Joel P Joel P 10/17/20 08:58AM
  Re: Electronic sequence shifter?Re: * wormdirt * * wormdirt * 11/23/20 03:00PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 11/23/20 03:56PM
  Re: Electronic sequence shifter?Re: Dirty30 Dillon Dirty30 Dillon 11/23/20 06:03PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 11/23/20 08:01PM
  Re: Electronic sequence shifter?Re: Graham Motzing Graham Motzing 11/24/20 05:35PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 11/25/20 04:47AM
  Re: Electronic sequence shifter?Re: jumpsuit steve jumpsuit steve 12/11/20 08:47AM
  Re: Electronic sequence shifter?Re: Totally normal JBOT Totally normal JBOT 12/11/20 12:01PM
  Re: Electronic sequence shifter?Re: ✨KARL✨RAY ✨JEBSON✨ ✨KARL✨RAY ✨JEBSON✨ 12/11/20 05:36PM
  Re: Electronic sequence shifter?Re: jumpsuit steve jumpsuit steve 12/11/20 08:53PM
  Re: Electronic sequence shifter?Re: Totally normal JBOT Totally normal JBOT 12/11/20 09:03PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/23/21 12:59PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/23/21 02:01PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/24/21 01:40PM
  Re: Electronic sequence shifter?Re: Totally normal JBOT Totally normal JBOT 01/24/21 02:20PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/24/21 02:54PM
  Re: Electronic sequence shifter?Re: Totally normal JBOT Totally normal JBOT 01/24/21 03:10PM
  Re: Electronic sequence shifter?Re: Aaron Blair Aaron Blair 01/24/21 03:25PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/25/21 12:47PM
  Re: Electronic sequence shifter?Re: Jay Rivett Jay Rivett 01/25/21 12:52PM
  Re: Electronic sequence shifter?Re: Dirty30 Dillon Dirty30 Dillon 01/25/21 01:01PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/25/21 04:18PM
  Re: Electronic sequence shifter?Re: Totally normal JBOT Totally normal JBOT 01/25/21 07:24PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/25/21 08:06PM
  Re: Electronic sequence shifter?Re: Totally normal JBOT Totally normal JBOT 01/25/21 08:39PM
  Re: Electronic sequence shifter?Re: Dirty30 Dillon Dirty30 Dillon 01/26/21 12:24AM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/26/21 02:06AM
  Re: Electronic sequence shifter?Re: Totally normal JBOT Totally normal JBOT 01/26/21 11:15AM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/26/21 01:21PM
  Re: Electronic sequence shifter?Re: * wormdirt * * wormdirt * 01/26/21 01:53PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/26/21 02:11PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/26/21 02:20PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/26/21 02:34PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/26/21 04:41PM
  Re: Electronic sequence shifter?Re: Jay Rivett Jay Rivett 01/27/21 11:23AM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/27/21 12:37PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/27/21 03:08PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/27/21 03:48PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/27/21 04:55PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/27/21 09:10PM
  Re: Electronic sequence shifter?Re: Totally normal JBOT Totally normal JBOT 01/27/21 09:13PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/27/21 09:36PM
  Re: Electronic sequence shifter?Re: Totally normal JBOT Totally normal JBOT 01/27/21 09:46PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/27/21 09:56PM
  Re: Electronic sequence shifter?Re: Jay Rivett Jay Rivett 01/28/21 03:03AM
  Re: Electronic sequence shifter?Re: * wormdirt * * wormdirt * 01/24/21 04:24PM
  Re: Electronic sequence shifter?Re: Joel P Joel P 01/26/21 07:45AM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/28/21 03:20PM
  Re: Electronic sequence shifter?Re: * wormdirt * * wormdirt * 01/28/21 03:30PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/28/21 04:14PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/28/21 04:26PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/28/21 06:41PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/28/21 08:39PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/28/21 10:01PM
  Re: Electronic sequence shifter?Re: Totally normal JBOT Totally normal JBOT 01/28/21 10:21PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/28/21 11:10PM
  Re: Electronic sequence shifter?Re: Daniel '' Daniel '' 01/28/21 10:52PM
  Re: Electronic sequence shifter?Re: Jay Rivett Jay Rivett 01/29/21 09:13AM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/29/21 10:46AM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/29/21 08:00PM
  Re: Electronic sequence shifter?Re: Totally normal JBOT Totally normal JBOT 01/29/21 08:13PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/29/21 09:05PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/29/21 11:49PM
  Re: Electronic sequence shifter?Re: Totally normal JBOT Totally normal JBOT 01/29/21 11:53PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/30/21 02:36AM
  Re: Electronic sequence shifter?Re: Totally normal JBOT Totally normal JBOT 01/30/21 10:10AM
  Re: Electronic sequence shifter?Re: Jay Rivett Jay Rivett 01/30/21 11:48AM
  Re: Electronic sequence shifter?Re: Totally normal JBOT Totally normal JBOT 01/30/21 11:55AM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/30/21 02:03PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 02/04/21 08:01PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 02/04/21 08:33PM
  Re: Electronic sequence shifter?Re: Aaron Blair Aaron Blair 02/04/21 09:06PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 02/04/21 09:18PM
  Re: Electronic sequence shifter?Re: Blake Totally a real doctor Blake Totally a real doctor 02/04/21 09:35PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 02/04/21 10:32PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 02/14/21 11:52PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 02/14/21 11:55PM
  Re: Electronic sequence shifter?Re: Terbo Speghetti Terbo Speghetti 03/23/21 04:42PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 03/23/21 06:16PM
