Re: Electronic sequence shifter?
jumpsuit steve /
First I hated this thing, then I forgot about it. which was fine.
Then I was thinking about landspeed bikes and this damn thing popped in my head.
One of the biggest limiting factors in making usable HP with little 2Ts is narrow powerband.
so, thinking about "short" speed runs you would want a strong rate of acceleration - i.e. 1-2 miles vs 6 miles (is it?) to get up to speed at a place like bonneville.
(compared to having a limited number of shift points where a wide ratio gearbox might make more sense if you had the time/space)
So I'm wondering about this kind of tech for manual (or automatic) digital control of gearing relative to RPM. so, not like 6 shift points, but "infinite" (based on resolution of stepper motor relative to pulley ramp angles etc etc.) just like a CVT is supposed to be. but instead of using the technology to reduce the efficiency of a CVT by limiting its tunability, use it for more precise control vs my foot on launch lever and or springs and weights.
not that the buddfab at the mile doing 96 is a bad thing.
that being said, a "well tuned" setup works great for most applications, and even manual control gives you just that. but they have input and regulation flaws. So, I'm curious if this is a way toward maximum power potential.............
  Electronic sequence shifter?Topic by: Bas Autowas Bas Autowas 10/16/20 07:57AM
  Re: Electronic sequence shifter?Re: P D P D 10/16/20 08:47AM
  Re: Electronic sequence shifter?Re: Dirty30 Dillon Dirty30 Dillon 10/16/20 09:32AM
  Re: Electronic sequence shifter?Re: Beach Club Nick Beach Club Nick 10/16/20 11:48AM
  Re: Electronic sequence shifter?Re: Totally normal JBOT Totally normal JBOT 10/16/20 12:16PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 11/23/20 02:14AM
  Re: Electronic sequence shifter?Re: Totally normal JBOT Totally normal JBOT 11/23/20 11:32AM
  Re: Electronic sequence shifter?Re: Born to be WillD Born to be WillD 10/16/20 03:10PM
  Re: Electronic sequence shifter?Re: Joel P Joel P 10/17/20 08:58AM
  Re: Electronic sequence shifter?Re: * wormdirt * * wormdirt * 11/23/20 03:00PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 11/23/20 03:56PM
  Re: Electronic sequence shifter?Re: Dirty30 Dillon Dirty30 Dillon 11/23/20 06:03PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 11/23/20 08:01PM
  Re: Electronic sequence shifter?Re: Graham Motzing Graham Motzing 11/24/20 05:35PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 11/25/20 04:47AM
  Re: Electronic sequence shifter?Re: jumpsuit steve jumpsuit steve 12/11/20 08:47AM
  Re: Electronic sequence shifter?Re: Totally normal JBOT Totally normal JBOT 12/11/20 12:01PM
  Re: Electronic sequence shifter?Re: ✨KARL✨RAY ✨JEBSON✨ ✨KARL✨RAY ✨JEBSON✨ 12/11/20 05:36PM
  Re: Electronic sequence shifter?Re: jumpsuit steve jumpsuit steve 12/11/20 08:53PM
  Re: Electronic sequence shifter?Re: Totally normal JBOT Totally normal JBOT 12/11/20 09:03PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/23/21 12:59PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/23/21 02:01PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/24/21 01:40PM
  Re: Electronic sequence shifter?Re: Totally normal JBOT Totally normal JBOT 01/24/21 02:20PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/24/21 02:54PM
  Re: Electronic sequence shifter?Re: Totally normal JBOT Totally normal JBOT 01/24/21 03:10PM
  Re: Electronic sequence shifter?Re: Aaron Blair Aaron Blair 01/24/21 03:25PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/25/21 12:47PM
  Re: Electronic sequence shifter?Re: Jay Rivett Jay Rivett 01/25/21 12:52PM
  Re: Electronic sequence shifter?Re: Dirty30 Dillon Dirty30 Dillon 01/25/21 01:01PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/25/21 04:18PM
  Re: Electronic sequence shifter?Re: Totally normal JBOT Totally normal JBOT 01/25/21 07:24PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/25/21 08:06PM
  Re: Electronic sequence shifter?Re: Totally normal JBOT Totally normal JBOT 01/25/21 08:39PM
  Re: Electronic sequence shifter?Re: Dirty30 Dillon Dirty30 Dillon 01/26/21 12:24AM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/26/21 02:06AM
  Re: Electronic sequence shifter?Re: Totally normal JBOT Totally normal JBOT 01/26/21 11:15AM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/26/21 01:21PM
  Re: Electronic sequence shifter?Re: * wormdirt * * wormdirt * 01/26/21 01:53PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/26/21 02:11PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/26/21 02:20PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/26/21 02:34PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/26/21 04:41PM
  Re: Electronic sequence shifter?Re: Jay Rivett Jay Rivett 01/27/21 11:23AM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/27/21 12:37PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/27/21 03:08PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/27/21 03:48PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/27/21 04:55PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/27/21 09:10PM
  Re: Electronic sequence shifter?Re: Totally normal JBOT Totally normal JBOT 01/27/21 09:13PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/27/21 09:36PM
  Re: Electronic sequence shifter?Re: Totally normal JBOT Totally normal JBOT 01/27/21 09:46PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/27/21 09:56PM
  Re: Electronic sequence shifter?Re: Jay Rivett Jay Rivett 01/28/21 03:03AM
  Re: Electronic sequence shifter?Re: * wormdirt * * wormdirt * 01/24/21 04:24PM
  Re: Electronic sequence shifter?Re: Joel P Joel P 01/26/21 07:45AM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/28/21 03:20PM
  Re: Electronic sequence shifter?Re: * wormdirt * * wormdirt * 01/28/21 03:30PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/28/21 04:14PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/28/21 04:26PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/28/21 06:41PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/28/21 08:39PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/28/21 10:01PM
  Re: Electronic sequence shifter?Re: Totally normal JBOT Totally normal JBOT 01/28/21 10:21PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/28/21 11:10PM
  Re: Electronic sequence shifter?Re: Daniel '' Daniel '' 01/28/21 10:52PM
  Re: Electronic sequence shifter?Re: Jay Rivett Jay Rivett 01/29/21 09:13AM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/29/21 10:46AM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/29/21 08:00PM
  Re: Electronic sequence shifter?Re: Totally normal JBOT Totally normal JBOT 01/29/21 08:13PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/29/21 09:05PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/29/21 11:49PM
  Re: Electronic sequence shifter?Re: Totally normal JBOT Totally normal JBOT 01/29/21 11:53PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/30/21 02:36AM
  Re: Electronic sequence shifter?Re: Totally normal JBOT Totally normal JBOT 01/30/21 10:10AM
  Re: Electronic sequence shifter?Re: Jay Rivett Jay Rivett 01/30/21 11:48AM
  Re: Electronic sequence shifter?Re: Totally normal JBOT Totally normal JBOT 01/30/21 11:55AM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 01/30/21 02:03PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 02/04/21 08:01PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 02/04/21 08:33PM
  Re: Electronic sequence shifter?Re: Aaron Blair Aaron Blair 02/04/21 09:06PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 02/04/21 09:18PM
  Re: Electronic sequence shifter?Re: Blake Totally a real doctor Blake Totally a real doctor 02/04/21 09:35PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 02/04/21 10:32PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 02/14/21 11:52PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 02/14/21 11:55PM
  Re: Electronic sequence shifter?Re: Terbo Speghetti Terbo Speghetti 03/23/21 04:42PM
  Re: Electronic sequence shifter?Re: operator error 696 420 operator error 696 420 03/23/21 06:16PM
