> Dirty30 Dillon Wrote:
> > Wesley Ambrosini Wrote:
> > So that replaces a variatior? And it opens or closes to simulate
> gears?
> It's just a variator that has a stepper motor built into it, and you
> program the amount of positions in it.
> This is going to be hard to adapt to a hobbit/derbi at all, as it's
> meant to sit between the belt and the cases, not at the outside like the
> two mopeds above. You'll have to have a cover/guard that supports the
> outside of the mechanism from spinning and twisting itself apart. Also,
> you will to full reg/rec and run a battery because I highly doubt that
> it's going to like anything be clean DC.
> Make sure you have the mildest contra you got in the rear so you don't
> yet the whole thing right off the end of the crank.
> The biggest hurtle is that either way you slice it, you have to adapt a
> different crank/mill the hobbit/derbi bell to accept what is in essence,
> just a novelty.
> If these were as effective as you think they could be, you'd see people
> using them.
Guys I’m not adding this onto a hobbit crank I’m slapping a zuma engine under the frame and running a tomos arrow front end 😬
