NU50 Carb oil injection
Timothy Hunter /
So I got a NU50 with no carb/air box. Ordered a carb off eBay, and it lacks a oil port. Can I just drill and tap a barn on the engine side of the carb and plumb it in? Or dose the oil need to go though some orifice.
Re: NU50 Carb oil injection
Jack Rutherford /
Run an oil line to the port at base of intake
Timothy Hunter /
I actually did that after I posted it. I realized I had a vacuum cap on their from when the auto choke was removed. I had to get a longer oil line. It's 3/32 I'd 3/16 od. It fits perfectly inside the barb with a bit of lube. She seems to running good now. A little smokey, but it had about 1/8 tank of premix left and I just dumped fuel on top of that. The oil sensor even works, the PO has just put a zip tie under the float to keep the light off.
