Re: Honda Cub C100 cylinder bore
Ross Maser /
More is more. You need to find a piston dome configured for the spark plug entering the combustion chamber from the side... or just punch it out to fit a Honda S65 piston installed backwards.
I have a n.o.s. "CYB" Honda high compression piston. The big bore gives so much more. A c110 cam will help even more on top of that.
