Stock E50 head with kit?
Will my stock e50 head work with this kit? Or do I need to mill it out, or buy a different head.
https://www.treatland.tv/ProductDetails.asp?ProductCode=puch-airsal-44mm-kit-02030844
Re: Stock E50 head with kit?
Probably Fred /
Pick your poison:
Use the stock head sand the compression rings flat then file or dremel squish band in to it
or buy a 44mm head at dos cycles then dremel inside bigger
Most heads you got to make the combustion chamber for stock size is not big enough
Probably Fred /
I make the 44 and 45 mm hi hi heads Look something like this depending on how the piston looks like:
Is there any tutorial available that I can follow to do this?
Probably Fred /
Ya it’s called marking it with a sharply, and Dremel it with carbide bits, Sandpaper roll it then use buffs like I showed in the second picture,
I do it all by hand but I’ve been doin cc’ing heads with die grinders and all kinds of things by hand so it’s nothing to me
Honestly a well tuned 50cc kit or a slap n go 70cc will work just as well with as the 64cc kit.
If you email treats, they'll probably have a head that, although not the same size, they'll recommend.
Well then, it sounds like I'm about to go grab some -sharplys- and get er' done.
Wow!
I wish I knew you when I
Was in moto x. I'm old now,
And peds do the trick.
Thanks.
Terbo Speghetti /
Dremeling a head sounds like the fastest way to ruin it.
I wouldn't do that to my bikes if you paid me.
Some of my fastest bikes was done that way. You have to have a steady hand though.
> hand though.
Or , at least , be able cover your big mistakes with smaller , less noticeable ones . LOL
I would have bought the 70cc airsal or treats kit but they were sold out, and didnt want to drop $200. I'm putting it on a maxi that I got for cheap and it was seized from sitting. Going to be my beater bike.
You bought a kit yet?
Yeah, airsal 64cc and a 15mm bing clone. I have a techno pipe that I’m gonna put on it as well. Should be a nice little ripper
