A35 airsal with puch high comp head
Looks like if I run no head gasket my studs aren't short enough before the threading starts to properly tighten down my head.. should I just trace this 50cc gasket and make it slightly wider on the opening? I'm sure the stock head would have no issue..piston clearance is good
Re: A35 airsal with puch high comp head
How far away is the threaded section with the head on?
you could find a thick washer maybe.
id have to be there to form a better opinion.
How thick is the head ?
I can't correctly measure the head as I can't find my caliper Guage .. I think if I make a gasket and use a washer I would be okay
I think you'd be fine with washers .
I'd recommend the thick crush/sealing type .
https://www.mcmaster.com/crush-washers/
I traced the other 50cc gasket and made it slightly wider by eyeing it.. you think its decent enough to run it ? About Same thickness as the the one I had (edited)
Is there a burn ring on the gasket you cut ?
What material did you cut it from ?
just use a bunch of washers, that gasket if not right is just gonna heat up n blow out.
> up n blow out.
Sounds good
Yeah bud. Just order the 70cc gasket or run no gasket with some copper spray. Then just use a washer or two to get the head to tighten down properly. That paper gasket will just burn out. And the 50cc gasket will only cause problems too.
I tell you I noticed a difference between running the stock tomos head and the high compression head! I know all bikes are different but my airsal runs alot better with stock head. Maybe your bike will be different
