> Sir Clip Wrote:
> Blue springs aren’t much of an upgrade from stock. The super stiffy
> springs are the way to go, 2-3 turns in from flush.
If you have a fish scale 25lbs is ideal.
But, 100%. Blue always leaves you wanting more and if you turn them in too far your more prone to break or bend the post. Get the Black ones and do two turns in. If not enough go a little more. If too much slip go to 1 or flush. I would never buy blue springs again. Easy tip to tune a e50 clutch is lay the bike on sits side so the oil does not come out and you can remove the clutch without having to swap the oil. 5 min spring adjustment.
