Re: 79 Magnum XK, Round intake port?
Probably Fred /
> Ben S Wrote:
> Nice! Good to know. It does have a 14mm intake. Any recs then for a
> little more tope end?
I made many posts about metal mesh 1/4-5/16 in hole in magnum chamber and end cap
Time around 18° Btdc Then Jet around 68-70 jet with 222 atomizer then tune the clutch with thick clutch springs and you will get this:
I also sand or mill puch heads flat and sometimes add a squish band, but on a piston that little it seems to make very little difference, Just flat works fine for more compression and power
