Re: The 2nd most powerful 50cc engine. (Casting a cylinder)
Kilian Münscher /
The engine is going to be used in offroad moped racing were most of the winning cylinders are ported polini or athena i forgot zündapp cs25 cylinder which have only a single exaust port. But the ported cylinders often have quite the high exaustport timing. As there are a maximum of 3 gears allowed you need to have quite the wide powerband to have a chance of winning.
I am hoping to achieve that with a large blowdown time area but low timing. The exaust port is extremely wide and shaped for best flow (picture). And yes that limits power, but that isn't terribly important as most other racers have "only" 12hp and with that portlayout and exaustport I am hoping to at least get 14hp but with a exactly as wide or even wider powerband. The pipe is going to be in resonance at quite high rpms somewhere between 12.500 and 13.500 rpm. Also the exaust opening on which the exaust bolts on is an elliptical constriction which helps to keep blowdown velocity high which should also help. Than the constricted ellipse goes over to a normal circular opening.
  The 2nd most powerful 50cc engine. (Casting a cylinder)Topic by: Kilian Münscher Kilian Münscher 09/12/20 07:19AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Martin Fotak Martin Fotak 09/12/20 10:21AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Ryan Graeme Ryan Graeme 09/12/20 10:27AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 09/12/20 11:02AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: A J A J 09/12/20 12:45PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 09/15/20 09:49AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 09/15/20 09:52AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: P D P D 09/15/20 10:11AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 09/15/20 11:35AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Dave Thacker Dave Thacker 09/15/20 08:18PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 09/16/20 12:51AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Sander Mulder Sander Mulder 09/16/20 03:22AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Sander Mulder Sander Mulder 09/16/20 08:28AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Dave Thacker Dave Thacker 09/16/20 08:39AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Sander Mulder Sander Mulder 09/16/20 08:44AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Sander Mulder Sander Mulder 09/16/20 10:40AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 09/20/20 08:20AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 09/16/20 11:49AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 09/17/20 10:11AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 09/17/20 10:20AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Aaron Blair Aaron Blair 09/17/20 10:55AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 09/17/20 03:05PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 09/18/20 09:24AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Jay Rivett Jay Rivett 09/18/20 07:36PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 09/19/20 12:22AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 09/19/20 07:01AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 09/19/20 09:24AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 09/20/20 05:23AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Sander Mulder Sander Mulder 09/20/20 05:25AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 09/20/20 05:39AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 09/20/20 12:16PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Graham Motzing Graham Motzing 09/26/20 12:31AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Dickie Gila Dickie Gila 10/13/20 10:13AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Totally normal JBOT Totally normal JBOT 12/11/20 02:46PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 09/26/20 02:13AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 09/26/20 09:17AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 09/28/20 09:31AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 10/03/20 09:59AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 10/13/20 11:53AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 10/24/20 11:38AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 10/25/20 11:43AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Graham Motzing Graham Motzing 10/25/20 01:49PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 10/26/20 01:48AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 10/27/20 09:55AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 10/27/20 10:10AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Josh G Josh G 10/27/20 06:59PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Graham Motzing Graham Motzing 10/27/20 07:34PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: James P James P 10/28/20 06:36AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 10/28/20 09:45AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: discontinuuity _ discontinuuity _ 10/28/20 03:50PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: James P James P 10/28/20 11:00AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 10/28/20 11:34AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 10/31/20 05:48AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Sander Mulder Sander Mulder 10/31/20 07:48AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 10/31/20 08:46AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 11/08/20 04:25AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Graham Motzing Graham Motzing 11/08/20 08:56AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 11/08/20 07:29AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 11/08/20 10:21AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Graham Motzing Graham Motzing 11/08/20 11:47PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Joe Schuitema Joe Schuitema 11/08/20 02:11PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 11/08/20 02:30PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 11/09/20 01:23AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Russell Huddy Russell Huddy 11/09/20 09:04AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 11/09/20 10:22AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Graham Motzing Graham Motzing 11/09/20 08:34PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Josh G Josh G 11/09/20 06:06PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Graham Motzing Graham Motzing 11/09/20 08:35PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 11/10/20 01:07AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Graham Motzing Graham Motzing 11/10/20 03:25PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F 11/10/20 06:49PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Graham Motzing Graham Motzing 11/10/20 08:40PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: discontinuuity _ discontinuuity _ 11/11/20 04:16PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 11/11/20 01:05AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Graham Motzing Graham Motzing 11/11/20 01:13AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 11/11/20 01:25AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Graham Motzing Graham Motzing 11/12/20 11:08AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 11/12/20 02:44AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 12/09/20 09:13AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Graham Motzing Graham Motzing 12/09/20 09:51AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Josh G Josh G 12/11/20 02:14PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Jay Rivett Jay Rivett 12/13/20 07:57PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 12/11/20 03:06PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Totally normal JBOT Totally normal JBOT 12/11/20 07:10PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 12/11/20 03:11PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 12/13/20 06:58AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Ryan Graeme Ryan Graeme 12/13/20 07:37AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Graham Motzing Graham Motzing 12/13/20 10:52AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 12/13/20 07:45AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 12/13/20 08:49AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Josh G Josh G 12/13/20 06:09PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 12/14/20 03:12AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Satan 666 Satan 666 12/14/20 09:27PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 12/15/20 12:06PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 12/22/20 03:57AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Graham Motzing Graham Motzing 12/22/20 07:49AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 01/07/21 06:19AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Graham Motzing Graham Motzing 01/07/21 03:34PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 01/07/21 06:20AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 01/07/21 04:14PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Graham Motzing Graham Motzing 01/07/21 04:43PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 01/07/21 04:58PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Graham Motzing Graham Motzing 01/07/21 06:12PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Jax Rhapsody Jax Rhapsody 03/06/21 12:29AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Jax Rhapsody Jax Rhapsody 12/24/21 08:49PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Josh G Josh G 01/07/21 06:31PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Graham Motzing Graham Motzing 01/08/21 09:39PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Sander Mulder Sander Mulder 01/14/21 06:48AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Graham Motzing Graham Motzing 01/14/21 10:13AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: niklaus _ niklaus _ 01/14/21 03:46PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: todd amundson todd amundson 01/14/21 11:44AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 01/15/21 02:03AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 01/14/21 10:41AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 01/14/21 02:10PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 02/28/21 02:07AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: DAЯT _ DAЯT _ 02/28/21 04:15AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Jay Rivett Jay Rivett 02/28/21 08:24AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Born to be WillD Born to be WillD 06/21/21 04:10PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 06/22/21 12:53AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 02/28/21 08:31AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Jay Rivett Jay Rivett 02/28/21 11:15AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 03/15/21 10:55AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 04/29/21 02:02PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Josh G Josh G 04/29/21 02:15PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 05/02/21 12:02PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Jay Rivett Jay Rivett 05/03/21 07:12AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Josh G Josh G 05/02/21 01:37PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 05/03/21 08:09AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Neal Summerln Neal Summerln 05/22/21 04:53AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Neal Summerln Neal Summerln 05/22/21 05:00AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Neal Summerln Neal Summerln 05/22/21 05:06AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Neal Summerln Neal Summerln 05/22/21 05:15AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 05/15/21 04:03PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: discontinuuity _ discontinuuity _ 05/15/21 04:12PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 05/16/21 02:49AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 05/22/21 04:39AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 05/22/21 05:06AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Neal Summerln Neal Summerln 05/22/21 05:21AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 05/22/21 05:19AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Neal Summerln Neal Summerln 05/22/21 05:32AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 05/22/21 05:26AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 05/22/21 06:03AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 05/22/21 10:55AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 05/31/21 03:36PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 06/20/21 03:47PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Benjamin Fossati Benjamin Fossati 12/12/21 10:07AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 12/19/21 05:50AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: P D P D 12/19/21 08:42AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 12/19/21 09:12AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Jay Rivett Jay Rivett 12/19/21 11:47AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 12/19/21 03:37PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Tom Boyd Tom Boyd 12/19/21 03:54PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: P D P D 12/19/21 04:53PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 12/20/21 09:01AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Graham Motzing Graham Motzing 12/20/21 12:59PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 12/20/21 05:18PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Benjamin Fossati Benjamin Fossati 12/24/21 08:57PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 12/25/21 06:16AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: daan SJAARLOOS daan SJAARLOOS 12/25/21 01:25PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 12/26/21 02:44PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Johnny Braaapp Johnny Braaapp 12/26/21 09:32PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 12/28/21 09:29AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 02/05/22 10:35AM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Jurrian Mulder Jurrian Mulder 02/05/22 06:16PM
  Re: The 2nd most powerful 50cc engine. (Casting a cylinder)Re: Kilian Münscher Kilian Münscher 02/06/22 07:12AM
