Re: MPG with a 65cc kit
Probably Fred /
> mike houlihan Wrote:
> i've looked at timing on two bikes now. the stock stators all seem to
> be retarded and can't get past 14 degrees without dremel. why is this?
Do you mean too advanced?
You don’t have to Dremel the Stator to get correct 14-17° btdc timing you could shrink the point gap to like 12-14 thou to get low timing before the screw hits the slot in the post
But E50s like 16-18 thou of a inch and Za50’s at least 17 thou for good kv and discharging of the capacitor
These are the only picture I could find but I may find another ones
Removing the material is already done for a Za50 as you could see the screw head goes halfway underneath coil laminate but sometimes I remove material on both sides right off the bat so I could use the Stators for both engines,
Most times you can’t use both wave washers because part of the screw head cannot fit underneath and you may have to shorten the screw too,
I don’t even remove the Stator completely from the wiring block
I just push the wiring down enough so stator comes off the end of the crank, throw a towel over everything else to keep the metal shavings away, Dremel it, blow everything clean with air hose and then put it back in and pull the wires back up
  MPG with a 65cc kitTopic by: simon judd simon judd 09/10/20 03:37PM
  Re: MPG with a 65cc kitRe: 666 420 666 420 09/10/20 04:49PM
  Re: MPG with a 65cc kitRe: Thomas Peffer Thomas Peffer 09/10/20 05:04PM
  Re: MPG with a 65cc kitRe: Probably Fred Probably Fred 09/10/20 05:47PM
  Re: MPG with a 65cc kitRe: Thomas Peffer Thomas Peffer 09/10/20 05:55PM
  Re: MPG with a 65cc kitRe: Probably Fred Probably Fred 09/10/20 06:06PM
  Re: MPG with a 65cc kitRe: Quattro Audi Quattro Audi 09/12/20 11:03PM
  Re: MPG with a 65cc kitRe: Dirty30 Dillon Dirty30 Dillon 09/11/20 10:39AM
  Re: MPG with a 65cc kitRe: kenny s kenny s 09/10/20 07:22PM
  Re: MPG with a 65cc kitRe: Sausage Head Sausage Head 09/11/20 01:24AM
  Re: MPG with a 65cc kitRe: Garrett The Kid Garrett The Kid 09/11/20 10:10AM
  Re: MPG with a 65cc kitRe: simon judd simon judd 09/11/20 10:44AM
  Re: MPG with a 65cc kitRe: EH FCC of the QCB EH FCC of the QCB 09/13/20 10:02PM
  Re: MPG with a 65cc kitRe: Dirty30 Dillon Dirty30 Dillon 09/13/20 10:17PM
  Re: MPG with a 65cc kitRe: roots to wings roots to wings 10/20/20 08:44AM
  Re: MPG with a 65cc kitRe: Probably Fred Probably Fred 10/20/20 10:12AM
  Re: MPG with a 65cc kitRe: roots to wings roots to wings 10/20/20 11:53AM
  Re: MPG with a 65cc kitRe: Probably Fred Probably Fred 10/20/20 01:13PM
  Re: MPG with a 65cc kitRe: roots to wings roots to wings 10/20/20 06:31PM
  Re: MPG with a 65cc kitRe: Graham Motzing Graham Motzing 10/21/20 02:55PM
  Re: MPG with a 65cc kitRe: mo pug mo pug 10/20/20 12:04PM
