Re: Hobbit.... and we're off!
Alex Hedrick /
Stage6 jug and some cheapo kickstart that I hope I can make better and usable lol
todd amundson /
What’s the crankshaft inside the images above? Splined partially. Appears to be piaggio or perhaps Jog 50. Thanks
Alex Hedrick /
Indeed a piaggio crank
Alex Hedrick /
Subframe is underway.. slowly making progress
Alex Hedrick /
Don't mind the mess.. I was all over the place this day lol
Dirty30 Dillon /
I hope you're putting the engine mounts on the subframe for this. Easily one of the most hobbling design flaws of the Hobbit is having to split sub from frame to pull engine
Alex Hedrick /
If you mean a new pivot point for the subframe, yes.. im going to cut the the original pivots off the cases and machine a new one that will be integrated in the subframe. Should much more solid and give more room around the motor for stuffs lol
