Re: Puch maxi Track toy
Sander Mulder /
> Jay Rivett Wrote:
> Oh snap! Glad you got it out on the track. Hope you can get your other
> cylinders to work how you want.
yes, i hope so.
i think this 50cc cylinder was about 8-9hp, cornering speed was as high as the other riders with 70cc, accleration and topend was much lower.
next race, on the same circuit, is on 8 may
engine is now out for rebuild, crank bearing spun in the case :(
^^^ so it was a good day at the track then. Ha! Look forward to more of all of this. Thanks again for sharing!
Sander Mulder /
Oops nr 1, wrong side of the moped to the track.
Knee down
Oops nr 2, destroyed a spark plug
Dang man. Killin it out there.
Why not build a fan and shroud. Lower temps probably see gains.
40:1 seems pretty lean for a race bike. I run klotz benoil in my Minarelli V1 at 20:1 for racing. I know it's a totally different setup, but still...
Sander Mulder /
> but still...
more oil is more heat. inspected the cylinder yesterday after a day of racing, nothing to see, everything in great condition.
Sander Mulder /
After 4 sessions on 40:1 mix. Addinol 2 stroke oil, special oil for air cooled engines.
Sander Mulder /
the little spots on the piston are from the broken sparkplug, nothing to worry about
> worry about
What brand spark plug breaks like that ?
Looks like an NGK.
That cylinder looks perfecto still.
Jurrian Mulder /
> Jay Rivett Wrote:
> Looks like an NGK.
it is indeed. But you have to keep in mind these are 10mm sparkplugs. They have a much thinner wall then the 'normal' sparkplugs. ( I am Sander his brother, I tuned the cylinder. ;))
Fantastic work on the exhaust port pictured. May I ask what size oiling holes line up with the exhaust bridge?
Sander Mulder /
i thought 3x 1mm holes
Mitas MC18 tires are replaced for a new set of Bridgestone Battlax BT39ss tires, soft compound, more grip ;)
(edited)
Sander Mulder /
I've got a little problem...
last thursday i had another training session. We were racing mopeds and pitbikes in the same class. In the third session, someone with a pitbike fell directly in front of me. My puch (and i) flipped over.
Not very much damage on the moped, only a broken front spoiler.
only my wrist was hurting a bit. it was ony getting worse, so we decided to go to the hospital to make some pictures. yes, a damaged bone in my right hand.
So the next weeks no racing, i have my arm in a cast.
short video, i'm at 0:04
After all that?
Damn pit bikes! Stupid groms.
Wat naar, zeker zo vroeg in het seizoen. Veel beterschap!
Sander Mulder /
haha, in the end its all racing, can't really blame him ;)
a bit bend, time for something new...
Sander Mulder /
Kilian Münscher /
Well shit.
Hope you get better soon
What’s the plans for the new split exhaust cylinder?
Sander Mulder /
> cooled engines.
This one?
Sander Mulder /
New exhaust pipe, bit higher from the ground. And for the looks ;)
Hgs pipe, produced for a ktm sx65.
2 weeks to go with my arm in a cast...
That just plain rocks!
Sidebleeed wins races
Big intake
3 transfer ports
Single ring piston
High compression
Good cooling
Is it a mud track?
Gasoline and pecock are located next to a hot surface (edited)
I'd be more worried about a crotch full of burnt oily fuel than cooling problems.
> problems.
This is what I though about too. I feel like it is aimed right at where my head would be in a tuck, and would shoot exhaust right up into my helmet.
But hey sander is light years beyond where I am with track racing so I really know nothing and can not comment on anything about performance.
Tough break (no pun intended[well maybe a little]). Hope you’re back to it soon. Your work has been so much fun to follow. Just don’t get too antsy and end up hurting yourself more!
Sander Mulder /
> Rubble Raiser Wrote:
> Tough break (no pun intended). Hope you’re back to it soon. Your work
haha, thank you, i will try.
for who's wondering, exhaust isn't finished, i am making a new tailpipe and muffler.
