Re: Puch maxi Track toy
Pussy Licker420 /
> Sander Mulder Wrote:
> Some other news, I'm currently producing this front sprocket cover/
> flywheel cover/ pull start cover. Stainless steel. Puch logo will be
> engraved on the open surface.
> First batch is 10 pieces.
Dam son!
Yes please. How much? I will probably need to get in on the second run due to low cash flow currently.
Sander Mulder /
I dont want them to be too expensive, probably around €40-50. I think that’s reasonable for laser cutted 2mm stainless steel.
I can do that all day! Seems super reasonable. Thank you sir!
Sander Mulder /
looks clean, right? :)
Heck yeah!!!!!! Bet it’s as much fun as it looks like too!
Pussy Licker420 /
Yea maybe to clean 🧼
Staan er voor dit jaar alweer races op het programma?
Sander Mulder /
ned: Eerste race/wegrace cursus staat gepland op 10 april. geen idee of dit door gaat ivm corona.
Eng.: First race is planned on 10 april. Dont know if its still continuing due to Covid.
Sander Mulder /
I've made a new cylinder head today, changeable combustion chamber.
I decided to run smaller spark plugs (10mm instead of 14mm shaft), should be better for performance.
This head is almost finished, only need to make the thread for the sparkplug.
Inner head has a clearance of 1/100st MM or 0.0004 ″ inch, pretty tight ;) '
Pussy Licker420 /
> sparkplug.
Omg 😳 dude wtf
Kilian Münscher /
How did you designe the combustion chamber shape ? Did you use some kind of programm
That head is a game changer! Make these for sale too brotha!
Sander Mulder /
> of programm
didn't use a programm, only a nice shape and good volume. made with some radius cutting tools on my lathe.
unfortunatly, those are too expensive to make and sell.
but there are already Kreidler heads with changeable chambers,
https://www.vhs-tuning.nl/kreidlershop/product/347-kreidler-bmp-cilinderkop-met-losse-verbrandingskamer
easy to fit on a puch engine.
Thanks for the link to the kreidler heads. But you let me worry about what is too expensive... I feel like I have seen clutches for over $300 and cylinders over $600. So unless the head is over $300 I'm betting it would be something some tuners would jump on. Not all of us are quite as shop literate as yourself to make such wonderful toys.
But I totally get it if it is not "worth" your time. Ha!
Totally normal JBOT /
Looks great! Just buy a lathe and make your own.
Having a lathe is the real game changer.
Just buy stock on eBay and go crazy
Why did u leave the plug center sticking up like that in the combustion chamber? I haven’t seen head designs like that
Sander Mulder /
Some say its better, never tested it by myself on a dyno,
(edited)
I see the wisdom in it. Did you make it for Es long reach plugs?
I know I gotta save my monies up and get at least a HF cheapo lathe. Then learn how to weld and I would be all set. Time and effort for sure.
Just got a part time job to actually have a cash flow again. Ha!
Sander Mulder /
made mine on a cheap lathe,
a cool render ;)
I made the spark plug thread today, head is now ready to use. I've got some weird NGK spark plug with 2 bridges.
Pussy Licker420 /
> a cool render ;)
What I never understood was those stupid e3 spark plug and they would promote them using drag cars ( great another electrode to brake off a destroy the motor)
It’s like Jim bob using two lighters for one bucket of gas, it doesn’t matter!
Burning off unwanted gases with an after burn I do understand
> a cool render ;)
This is super rad. Never thought of having head inserts on an air cooled head.
very cool. never seen an air cooled modular head.
Gopeds used modular combustion chambers on some headkits, 13:1, 15:1, 17:1 alky hell yeah
Sander Mulder /
I've made some progress this evening. engine is almost ready to run. It has enough compression ;)
Digital PVL ignition on 6.5mm BTDC
hope to get it running by the beginning of next week. Also some dyno runs then. Our goal is at least 15WHP
Pussy Licker420 /
I don’t know about 15 whp...
Case inducted, add a scooter kit and use that third transfer for what it’s good for
It Looks Great! What intake is that?
Well that intake is sitting on some vforce reeds I know that.
Cant wait to see some vids of this bad boy.
Sander Mulder /
indeed a Vforce 3 reed valve, originaly from a KTM sx65.
I've made the stainless steel manifold by myself.
