Re: Puch maxi Track toy
That dimpling tho
Sander Mulder /
Those arent dimples, just rounds in the blank coating
Likely have the same effect . Short term anyway .
> https://toronda.com/product/cilinder-puch-maxi-e50-high-end-race/
> Fastest puch cylinder you can buy, 18hp possible, straight out of the
> box
> Only 70cc/45mm piston
> Good work here in Holland
Looks like ya need case induction to run as well! Would also be interested in seeing the ports. Also surprised its not watercooled. Do they make a head for the kit as well?
Not much info about it on that site, but 18 sounds sweet:)
Dirty30 Dillon /
That's a beauty cylinder. And 650 euros is like totally acceptable for something small batch made.
I know the US moped market is budget friendly, but try buying an equivalent cylinder for Lambretta or Vespa scoots. Those dudes don't even bat an eye at spending 1000 euro to rebuild a bike, to basically STOCK functionality.
What you think about that toronda crankshaft? Puch shop also sell them. And i know that i do not need it but still i want it:)
But strange that there is no cylinder head, isnt it? Should you not use a correct squsih band with a racing cylinder like that?
Sander Mulder /
Torondo is a bit new, cylinder is out since last week.
Crank is balanced for a 45mm piston, good quality, less vibration.
I dont know if there’s a matching head yet
Is Torondo een herstart van Toro Racing Division (TRD)? Ik zie dat die hun facebook hebben verwijderd.
todd amundson /
That helps
> box
Thanks Sander, we really appreciate it.
We developped this cylinder during this winter and our driver Sarik Roufs tested it in 2 private training sessions already.
Combined with the right parts (exhaust, ignition, cylinder head etc.) this cylinder is even capable of producing quite a bit more then 18HP. We will upload a dynograph of one of our Toronda engines this evening.
Nee zeker niet... Toronda heeft niks met het vroegere TRD te maken.
> > box
Pictures of the ports will be available soon at our webshop. Its air cooled btw, while this is required for most Puch racing classes here in the Netherlands and Switserland for example.
We are also producing a CNC made cylinderhead with our advised combustion chamber shape and compression ratio. This head will be soon available at our webshop. Prototype pictures will be available at the shop this week.
> > box
As promised, the dyno graph of the engine that we used for the development work.
Woahhhhhhh nice!
22hp from an e50. My mind is blown. Yeah not stock at all, but dang. Those Austrian engineers had no idea this would be a thing. They stamped 2hp at the most on these.
Impressive for sure.. Sarik, can you comment on how long you'd expect a motor like that to last? i'm assuming that's primarily a race application and it may need "maintenance" after X number of sessions, etc?
From the sports car world, for example, you can coax several times the stock horsepower out of an old British engine (MG / Triumph) for the track, however the life of those engines may be measured in hours. It's all factored into the equation and most owners accept that...
Sander Mulder /
A little update on my 60cc resleeved gilardoni,
I destroyed it, due to some missing piston pin clips or the went out. More info soon. Cylinder needs to be bored to be useable again.
Well, if I’m understanding that graph, the power starts around 10K and builds to almost 14K.
For us ordinary “performance” moped guys, 10K is like peak rpm for a “usuable” moped. As in, it doesn’t explode all the time and you can cruise around town.
At least, thats the timing and gearing I shoot for with porting and such. I am very close to Roffmans style though. Not his same methods, but I like going as fast as I can while not replacing stuff every 100 miles.
Still, it is hard to not dream and covet those screaming HPs from something like this. Much respect to those of you making it happen. I love watching it and maybe someday I will have the extra $/€ to build a wild machine for those days when moderation isn’t on the menu.
Matt Mahloch -- MBM Customs /
What’s up with that added jet on the TM24 on the website. That’s interesting.
Sander Mulder /
no big updates yet. split my engine today, a few points:
-Big end bearing doesn't feel fine
- there are a few signes of gas blowback in the engine, crankcase was a bit black.
probably because the ignition was not set right.
- no other things on the engine
so, crank got a new conrod today, cylinder gets a oversize piston next week,so the engine should be ready within 2 weeks.
and just a nice pic of the internals :))
Sander Mulder /
has changed a bit, next thing to do is lower the front.
engine is almost ready for assembly.
That gear set is making me feel things. You’re gonna have video when all’s said and done right. This bike is gonna make all the right sounds.
I like the way this looks now! Cant wait to see it running. Love that Korado wheel up front.
Sander Mulder /
looks better with a shorter fork.
machined the cases to fit a KTM SX65 piston
Hahaha I didn’t wanna say anything but that fucking rake was killing me.
Thank you so much! Only problem now is the bars don’t fit? Right
Sander Mulder /
i've got bigger problems now :'( Forks are bend...
ordered new forks, should arrive this week.
How did that happen!?
It’s funny because I know a lot of guys me included that probably wouldn’t of even notice it
Sander Mulder /
well.. First of all, the previous owner crashed with it, didn't notice anything till yesterday. I was working on the fork to make it shorter. Once everything was done, I was ready assemble it again, this time one fork was rotated a bit, so was bended to the inside. Still didn't notice anything, but then it was time to put the front wheel back in, didn't fit because the distance between the legs was to small.
got my new forks today :)
Sander Mulder /
Some other news, I'm currently producing this front sprocket cover/ flywheel cover/ pull start cover. Stainless steel. Puch logo will be engraved on the open surface.
First batch is 10 pieces.
