Re: Meddling with a Wisp
Tom Boyd /
> Jay Rivett wrote:
> Super weird man. Are you using a timing light for your timing? The
> best results I get from timing points is with a plunge style timing
> tool. Like the buzetti ones that treatland sells. They can be a little
> janky as the spring in them ends up making the marks a little off but it
> tends to be the best timing I get. Cdi setups have to be done with a
> timing light as in most cases you lose the keyway, but I have always had
> weird results like you are getting when trying a light with points.
Yes mate, I use one of these guys 👇 to set the timing.
Then put a bit of tape on the flywheel, mark at tdc, then put a line where I've set the timing, say 17° and 5° either side and check it running with a strobe. I've been surprised at how accurate that little timing tool is.
> Kenneth Hill wrote:
> try a #7., 72 jet.
Hey Ken, I've tried a std. #7 and a couple of modified #7s and haven't got on very well with them hence the redesigned slide. However I did try a 72 jet today, timing set at 21° (½ throttle it retarded by 3°, strobe crapped out at full whack🤷‍♂️). Started off ok, felt a little rich off idle but was running well enough to go for a blat, went round the housing estate to warm it up to 130°c. Popped out onto the main road for a speed run, got up to top speed and then same thing happened again but worse, refused to run clean at all and had to coast into a side road (temps never got past 145°c).
I'm thinking the problem might be fuel starvation, 72 jet draining the float bowl faster giving worse symptoms, I've been through literally everything else.
  Meddling with a WispTopic by: Tom Boyd Tom Boyd 07/27/20 04:01PM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 07/27/20 07:20PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 07/28/20 10:57AM
  Re: Meddling with a WispRe: P D P D 07/28/20 12:18PM
  Re: Meddling with a WispRe: Jeremy Homser Jeremy Homser 07/27/20 08:11PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 07/28/20 11:07AM
  Re: Meddling with a WispRe: Stephen Keller Stephen Keller 07/28/20 02:05PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 07/29/20 12:56AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 07/29/20 12:59AM
  Re: Meddling with a WispRe: P D P D 07/29/20 07:58AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/20/20 05:40AM
  Re: Meddling with a WispRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 08/20/20 03:35PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/22/20 11:05AM
  Re: Meddling with a WispRe: Rebel Moby Rebel Moby 08/22/20 09:25PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/23/20 03:35PM
  Re: Meddling with a WispRe: Rebel Moby Rebel Moby 08/25/20 09:32AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/24/20 06:10PM
  Re: Meddling with a WispRe: Rebel Moby Rebel Moby 08/25/20 09:45AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/25/20 06:19PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/26/20 04:56PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/26/20 05:04PM
  Re: Meddling with a WispRe: discontinuuity _ discontinuuity _ 08/29/20 04:22AM
  Re: Meddling with a WispRe: James P James P 08/29/20 05:03AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/29/20 01:51PM
  Re: Meddling with a WispRe: discontinuuity _ discontinuuity _ 08/29/20 05:04PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/29/20 06:29PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/17/20 04:14PM
  Re: Meddling with a WispRe: Rebel Moby Rebel Moby 09/18/20 10:48AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/23/20 03:32PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/23/20 04:05PM
  Re: Meddling with a WispRe: Rebel Moby Rebel Moby 09/24/20 09:40AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/24/20 05:42PM
  Re: Meddling with a WispRe: P D P D 09/24/20 07:19PM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 09/28/20 08:44AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/29/20 02:54PM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 09/30/20 08:40AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 10/08/20 04:58PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 10/08/20 05:07PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 10/08/20 05:15PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 10/08/20 05:22PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 10/08/20 05:24PM
  Re: Meddling with a WispRe: Jeremy Homser Jeremy Homser 10/08/20 05:34PM
  Re: Meddling with a WispRe: P D P D 10/08/20 07:03PM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 10/09/20 11:07PM
  Re: Meddling with a WispRe: Graham Motzing Graham Motzing 10/10/20 10:12AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 10/10/20 04:37PM
  Re: Meddling with a WispRe: Rebel Moby Rebel Moby 10/12/20 01:33PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 10/12/20 05:58PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 10/17/20 10:40AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 10/27/20 03:17AM
  Re: Meddling with a WispRe: Rebel Moby Rebel Moby 10/29/20 10:48AM
  Re: Meddling with a WispRe: Rebel Moby Rebel Moby 10/29/20 10:49AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/26/20 04:53PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/26/20 04:58PM
  Re: Meddling with a WispRe: P D P D 09/26/20 07:02PM
  Re: Meddling with a WispRe: b to the eff b to the eff 10/29/20 11:44AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 11/01/20 03:06AM
  Re: Meddling with a WispRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 11/01/20 01:11PM
  Re: Meddling with a WispRe: Graham Motzing Graham Motzing 11/01/20 01:30PM
  Re: Meddling with a WispRe: P D P D 11/01/20 01:51PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 11/02/20 03:45AM
  Re: Meddling with a WispRe: Mike Boyd Mike Boyd 11/01/20 11:41PM
  Re: Meddling with a WispRe: James P James P 11/02/20 06:02AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 11/02/20 12:30PM
  Re: Meddling with a WispRe: Aaron Blair Aaron Blair 11/02/20 06:36AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 03/13/21 12:15AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 03/13/21 12:20AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 03/13/21 12:27AM
  Re: Meddling with a WispRe: Ryan Graeme Ryan Graeme 03/13/21 03:45AM
  Re: Meddling with a WispRe: James P James P 03/13/21 03:13AM
  Re: Meddling with a WispRe: DAЯT _ DAЯT _ 03/13/21 01:35PM
  Re: Meddling with a WispRe: Graham Motzing Graham Motzing 03/13/21 06:04PM
  Re: Meddling with a WispRe: Ryan Graeme Ryan Graeme 03/14/21 04:24AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 03/15/21 06:08PM
  Re: Meddling with a WispRe: Ryan Graeme Ryan Graeme 03/16/21 02:30AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 03/17/21 12:40PM
  Re: Meddling with a WispRe: Graham Motzing Graham Motzing 03/17/21 04:30PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 03/17/21 05:56PM
  Re: Meddling with a WispRe: Dirty30 Dillon Dirty30 Dillon 03/17/21 06:13PM
  Re: Meddling with a WispRe: P D P D 03/17/21 06:53PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 03/18/21 10:03PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 04/06/21 06:39PM
  Re: Meddling with a WispRe: DAЯT _ DAЯT _ 04/08/21 03:47AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 04/08/21 02:42PM
  Re: Meddling with a WispRe: Ryan Graeme Ryan Graeme 04/08/21 03:42PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 04/09/21 03:39PM
  Re: Meddling with a WispRe: P D P D 04/09/21 05:19PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 04/09/21 10:23PM
  Re: Meddling with a WispRe: Totally normal JBOT Totally normal JBOT 04/09/21 11:55PM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 03/17/21 01:20PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 03/14/21 01:40AM
  Re: Meddling with a WispRe: Chris Squid Chris Squid 04/08/21 01:44PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 07/21/21 03:27PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 07/21/21 03:33PM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 07/22/21 10:37AM
  Re: Meddling with a WispRe: DAЯT _ DAЯT _ 07/21/21 03:40PM
  Re: Meddling with a WispRe: Born to be WillD Born to be WillD 07/22/21 01:47PM
  Re: Meddling with a WispRe: Mike Boyd Mike Boyd 07/22/21 02:59PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 07/30/21 04:55PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 07/30/21 05:01PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 07/30/21 05:05PM
  Re: Meddling with a WispRe: Mike Boyd Mike Boyd 07/30/21 05:43PM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 07/30/21 10:33PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/07/21 05:11PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/07/21 05:16PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/07/21 05:23PM
  Re: Meddling with a WispRe: Graham Motzing Graham Motzing 07/30/21 07:43PM
  Re: Meddling with a WispRe: James P James P 08/07/21 07:57PM
  Re: Meddling with a WispRe: Stephen Keller Stephen Keller 08/08/21 12:04AM
  Re: Meddling with a WispRe: P D P D 08/08/21 07:44AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/08/21 05:22PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/14/21 12:27PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/14/21 12:34PM
  Re: Meddling with a WispRe: Stephen Keller Stephen Keller 08/14/21 03:51PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/14/21 04:07PM
  Re: Meddling with a WispRe: Mike Boyd Mike Boyd 08/14/21 03:26PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/14/21 03:53PM
  Re: Meddling with a WispRe: Stephen Keller Stephen Keller 08/14/21 04:43PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/15/21 03:31AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/19/21 03:55PM
  Re: Meddling with a WispRe: pat splat pat splat 08/19/21 11:32PM
  Re: Meddling with a WispRe: Stephen Keller Stephen Keller 08/20/21 03:14AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/20/21 04:53PM
  Re: Meddling with a WispRe: Mike Boyd Mike Boyd 08/20/21 06:03PM
  Re: Meddling with a WispRe: Aaron Blair Aaron Blair 08/21/21 04:37AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/21/21 06:22PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/05/21 05:35PM
  Re: Meddling with a WispRe: P D P D 09/06/21 09:48AM
  Re: Meddling with a WispRe: Mike Boyd Mike Boyd 09/06/21 11:02AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/06/21 04:16PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/06/21 04:36PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/15/21 04:34PM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 09/19/21 11:06AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 04/25/22 05:10PM
  Re: Meddling with a WispRe: Mike Boyd Mike Boyd 04/25/22 06:43PM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 04/26/22 10:24AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 04/26/22 04:41PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 04/27/22 04:49PM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 04/28/22 10:11AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 04/28/22 03:50PM
  Re: Meddling with a WispRe: Graham Motzing Graham Motzing 04/28/22 04:54PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 04/29/22 05:15PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 05/03/22 04:52PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 05/07/22 06:15AM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 05/10/22 11:21PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 05/11/22 03:49PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 05/12/22 04:24PM
  Re: Meddling with a WispRe: P D P D 05/12/22 05:47PM
  Re: Meddling with a WispRe: Graham Motzing Graham Motzing 04/27/22 07:09PM
  Re: Meddling with a WispRe: I M I M 05/09/22 04:28AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 05/10/22 03:52PM
  Re: Meddling with a WispRe: I M I M 05/11/22 09:22AM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 05/12/22 05:00PM
  Re: Meddling with a WispRe: Simon Williams Simon Williams 05/15/22 05:04PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 05/16/22 03:52PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 07/25/22 02:20AM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 07/25/22 02:36AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 07/25/22 04:55PM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 07/26/22 10:42AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/02/22 04:42PM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 09/02/22 09:45PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/03/22 01:19AM
  Re: Meddling with a WispRe: Kenneth Hill Kenneth Hill 09/03/22 03:47AM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 09/03/22 11:09AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/03/22 05:21PM
  Re: Meddling with a WispRe: Kenneth Hill Kenneth Hill 09/03/22 07:55PM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 09/04/22 11:13AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/04/22 04:21PM
  Re: Meddling with a WispRe: Kenneth Hill Kenneth Hill 09/05/22 05:50AM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 09/05/22 09:44AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/05/22 04:18PM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 09/06/22 10:24AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/06/22 05:21PM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 09/06/22 07:58PM
  Re: Meddling with a WispRe: Kenneth Hill Kenneth Hill 09/07/22 01:14AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/07/22 04:41PM
  Re: Meddling with a WispRe: Kenneth Hill Kenneth Hill 09/07/22 08:47PM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 09/08/22 10:31AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/08/22 05:22PM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 09/09/22 10:08AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/09/22 04:18PM
  Re: Meddling with a WispRe: ◕ ‿ ◕ ◕ ‿ ◕ 07/29/22 04:36PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/29/22 02:50AM
  Re: Meddling with a WispRe: P D P D 09/29/22 08:35AM
  Re: Meddling with a WispRe: Ryan Graeme Ryan Graeme 09/29/22 03:35PM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 09/30/22 10:49AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 10/01/22 06:38AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 10/01/22 05:16PM
