> pat splat Wrote:
> Just saw first and last pictures, nice work. All mobys ive had were
> smooth except when the mounts go out then its a jerky shaky thing. Id
> weld up some engine mounts n that springy hook thing. Or start
> balancing stuff magneto pulleys etc. Amazing how much energy lost to
> vibration instead of smoooothness
Cheers Pat, I'm probably being thick here but you lost me on "that springy hook thing"?
Good shout on balancing the external bits, hadn't thought of it but if the pulley is out that could cause serious vibration.
> Stephen Keller Wrote:
> Is it possible to isolate the upper mounts with rubber, a bushing, maybe
> something like what is used on the Model "7"? It would be extreme but I
> suppose one could "balance" and blueprint the engine? But$$$$.
Cheers Stephen, I'll pop these guys out and see what space I have to play with, iirc they're 6mm thick.
Any clue what rubber would hold up to that kind of heat?
As for engine balancing, I think that might be too overboard.....its only mopeds right? And can you really balance a single anyway?
