Re: Meddling with a Wisp
Rebel Moby /
You can drop the floor of the exhause carefully using a file so you can get alignment, or you can drop the cylinder a little with a thinner shim and slightly ramp the periphery of the piston crown at the transfers. Keep in mind that the two base gaskets you now need will have volume and also will compress, good practice is to have 4 tubes on the cylinder studs so you can torque the nuts onto the assembly while you index the cylinder.
If you do decide to ramp the crown, just be wary of the margin over the rings at the exhause. You do not want to take it down too far because the reversion wave from the expansion chamber will be blasting charge back into the cylinder. If it is knife edged then that area or the periphery can erode quickly.
  Meddling with a WispTopic by: Tom Boyd Tom Boyd 07/27/20 04:01PM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 07/27/20 07:20PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 07/28/20 10:57AM
  Re: Meddling with a WispRe: P D P D 07/28/20 12:18PM
  Re: Meddling with a WispRe: Jeremy Homser Jeremy Homser 07/27/20 08:11PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 07/28/20 11:07AM
  Re: Meddling with a WispRe: Stephen Keller Stephen Keller 07/28/20 02:05PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 07/29/20 12:56AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 07/29/20 12:59AM
  Re: Meddling with a WispRe: P D P D 07/29/20 07:58AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/20/20 05:40AM
  Re: Meddling with a WispRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 08/20/20 03:35PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/22/20 11:05AM
  Re: Meddling with a WispRe: Rebel Moby Rebel Moby 08/22/20 09:25PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/23/20 03:35PM
  Re: Meddling with a WispRe: Rebel Moby Rebel Moby 08/25/20 09:32AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/24/20 06:10PM
  Re: Meddling with a WispRe: Rebel Moby Rebel Moby 08/25/20 09:45AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/25/20 06:19PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/26/20 04:56PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/26/20 05:04PM
  Re: Meddling with a WispRe: discontinuuity _ discontinuuity _ 08/29/20 04:22AM
  Re: Meddling with a WispRe: James P James P 08/29/20 05:03AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/29/20 01:51PM
  Re: Meddling with a WispRe: discontinuuity _ discontinuuity _ 08/29/20 05:04PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/29/20 06:29PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/17/20 04:14PM
  Re: Meddling with a WispRe: Rebel Moby Rebel Moby 09/18/20 10:48AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/23/20 03:32PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/23/20 04:05PM
  Re: Meddling with a WispRe: Rebel Moby Rebel Moby 09/24/20 09:40AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/24/20 05:42PM
  Re: Meddling with a WispRe: P D P D 09/24/20 07:19PM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 09/28/20 08:44AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/29/20 02:54PM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 09/30/20 08:40AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 10/08/20 04:58PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 10/08/20 05:07PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 10/08/20 05:15PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 10/08/20 05:22PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 10/08/20 05:24PM
  Re: Meddling with a WispRe: Jeremy Homser Jeremy Homser 10/08/20 05:34PM
  Re: Meddling with a WispRe: P D P D 10/08/20 07:03PM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 10/09/20 11:07PM
  Re: Meddling with a WispRe: Graham Motzing Graham Motzing 10/10/20 10:12AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 10/10/20 04:37PM
  Re: Meddling with a WispRe: Rebel Moby Rebel Moby 10/12/20 01:33PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 10/12/20 05:58PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 10/17/20 10:40AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 10/27/20 03:17AM
  Re: Meddling with a WispRe: Rebel Moby Rebel Moby 10/29/20 10:48AM
  Re: Meddling with a WispRe: Rebel Moby Rebel Moby 10/29/20 10:49AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/26/20 04:53PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/26/20 04:58PM
  Re: Meddling with a WispRe: P D P D 09/26/20 07:02PM
  Re: Meddling with a WispRe: b to the eff b to the eff 10/29/20 11:44AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 11/01/20 03:06AM
  Re: Meddling with a WispRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 11/01/20 01:11PM
  Re: Meddling with a WispRe: Graham Motzing Graham Motzing 11/01/20 01:30PM
  Re: Meddling with a WispRe: P D P D 11/01/20 01:51PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 11/02/20 03:45AM
  Re: Meddling with a WispRe: Mike Boyd Mike Boyd 11/01/20 11:41PM
  Re: Meddling with a WispRe: James P James P 11/02/20 06:02AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 11/02/20 12:30PM
  Re: Meddling with a WispRe: Aaron Blair Aaron Blair 11/02/20 06:36AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 03/13/21 12:15AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 03/13/21 12:20AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 03/13/21 12:27AM
  Re: Meddling with a WispRe: Ryan Graeme Ryan Graeme 03/13/21 03:45AM
  Re: Meddling with a WispRe: James P James P 03/13/21 03:13AM
  Re: Meddling with a WispRe: DAЯT _ DAЯT _ 03/13/21 01:35PM
  Re: Meddling with a WispRe: Graham Motzing Graham Motzing 03/13/21 06:04PM
  Re: Meddling with a WispRe: Ryan Graeme Ryan Graeme 03/14/21 04:24AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 03/15/21 06:08PM
  Re: Meddling with a WispRe: Ryan Graeme Ryan Graeme 03/16/21 02:30AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 03/17/21 12:40PM
  Re: Meddling with a WispRe: Graham Motzing Graham Motzing 03/17/21 04:30PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 03/17/21 05:56PM
  Re: Meddling with a WispRe: Dirty30 Dillon Dirty30 Dillon 03/17/21 06:13PM
  Re: Meddling with a WispRe: P D P D 03/17/21 06:53PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 03/18/21 10:03PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 04/06/21 06:39PM
  Re: Meddling with a WispRe: DAЯT _ DAЯT _ 04/08/21 03:47AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 04/08/21 02:42PM
  Re: Meddling with a WispRe: Ryan Graeme Ryan Graeme 04/08/21 03:42PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 04/09/21 03:39PM
  Re: Meddling with a WispRe: P D P D 04/09/21 05:19PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 04/09/21 10:23PM
  Re: Meddling with a WispRe: FUCKN JBOT FUCKN JBOT 04/09/21 11:55PM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 03/17/21 01:20PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 03/14/21 01:40AM
  Re: Meddling with a WispRe: Chris Squid Chris Squid 04/08/21 01:44PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 07/21/21 03:27PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 07/21/21 03:33PM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 07/22/21 10:37AM
  Re: Meddling with a WispRe: DAЯT _ DAЯT _ 07/21/21 03:40PM
  Re: Meddling with a WispRe: Born to be WillD Born to be WillD 07/22/21 01:47PM
  Re: Meddling with a WispRe: Mike Boyd Mike Boyd 07/22/21 02:59PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 07/30/21 04:55PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 07/30/21 05:01PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 07/30/21 05:05PM
  Re: Meddling with a WispRe: Mike Boyd Mike Boyd 07/30/21 05:43PM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 07/30/21 10:33PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/07/21 05:11PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/07/21 05:16PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/07/21 05:23PM
  Re: Meddling with a WispRe: Graham Motzing Graham Motzing 07/30/21 07:43PM
  Re: Meddling with a WispRe: James P James P 08/07/21 07:57PM
  Re: Meddling with a WispRe: Stephen Keller Stephen Keller 08/08/21 12:04AM
  Re: Meddling with a WispRe: P D P D 08/08/21 07:44AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/08/21 05:22PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/14/21 12:27PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/14/21 12:34PM
  Re: Meddling with a WispRe: Stephen Keller Stephen Keller 08/14/21 03:51PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/14/21 04:07PM
  Re: Meddling with a WispRe: Mike Boyd Mike Boyd 08/14/21 03:26PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/14/21 03:53PM
  Re: Meddling with a WispRe: Stephen Keller Stephen Keller 08/14/21 04:43PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/15/21 03:31AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/19/21 03:55PM
  Re: Meddling with a WispRe: pat splat pat splat 08/19/21 11:32PM
  Re: Meddling with a WispRe: Stephen Keller Stephen Keller 08/20/21 03:14AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/20/21 04:53PM
  Re: Meddling with a WispRe: Mike Boyd Mike Boyd 08/20/21 06:03PM
  Re: Meddling with a WispRe: Aaron Blair Aaron Blair 08/21/21 04:37AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 08/21/21 06:22PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/05/21 05:35PM
  Re: Meddling with a WispRe: P D P D 09/06/21 09:48AM
  Re: Meddling with a WispRe: Mike Boyd Mike Boyd 09/06/21 11:02AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/06/21 04:16PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/06/21 04:36PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/15/21 04:34PM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 09/19/21 11:06AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 04/25/22 05:10PM
  Re: Meddling with a WispRe: Mike Boyd Mike Boyd 04/25/22 06:43PM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 04/26/22 10:24AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 04/26/22 04:41PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 04/27/22 04:49PM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 04/28/22 10:11AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 04/28/22 03:50PM
  Re: Meddling with a WispRe: Graham Motzing Graham Motzing 04/28/22 04:54PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 04/29/22 05:15PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 05/03/22 04:52PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 05/07/22 06:15AM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 05/10/22 11:21PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 05/11/22 03:49PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 05/12/22 04:24PM
  Re: Meddling with a WispRe: P D P D 05/12/22 05:47PM
  Re: Meddling with a WispRe: Graham Motzing Graham Motzing 04/27/22 07:09PM
  Re: Meddling with a WispRe: I M I M 05/09/22 04:28AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 05/10/22 03:52PM
  Re: Meddling with a WispRe: I M I M 05/11/22 09:22AM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 05/12/22 05:00PM
  Re: Meddling with a WispRe: Simon Williams Simon Williams 05/15/22 05:04PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 05/16/22 03:52PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 07/25/22 02:20AM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 07/25/22 02:36AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 07/25/22 04:55PM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 07/26/22 10:42AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/02/22 04:42PM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 09/02/22 09:45PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/03/22 01:19AM
  Re: Meddling with a WispRe: Kenneth Hill Kenneth Hill 09/03/22 03:47AM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 09/03/22 11:09AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/03/22 05:21PM
  Re: Meddling with a WispRe: Kenneth Hill Kenneth Hill 09/03/22 07:55PM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 09/04/22 11:13AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/04/22 04:21PM
  Re: Meddling with a WispRe: Kenneth Hill Kenneth Hill 09/05/22 05:50AM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 09/05/22 09:44AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/05/22 04:18PM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 09/06/22 10:24AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/06/22 05:21PM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 09/06/22 07:58PM
  Re: Meddling with a WispRe: Kenneth Hill Kenneth Hill 09/07/22 01:14AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/07/22 04:41PM
  Re: Meddling with a WispRe: Kenneth Hill Kenneth Hill 09/07/22 08:47PM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 09/08/22 10:31AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/08/22 05:22PM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 09/09/22 10:08AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/09/22 04:18PM
  Re: Meddling with a WispRe: â—• ‿ â—• â—• ‿ â—• 07/29/22 04:36PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 09/29/22 02:50AM
  Re: Meddling with a WispRe: P D P D 09/29/22 08:35AM
  Re: Meddling with a WispRe: Ryan Graeme Ryan Graeme 09/29/22 03:35PM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 09/30/22 10:49AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 10/01/22 06:38AM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 10/01/22 05:16PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 04/18/23 07:21PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 04/18/23 07:24PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 04/18/23 07:28PM
  Re: Meddling with a WispRe: Tom Boyd Tom Boyd 04/19/23 01:06PM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 04/20/23 10:52AM
  Re: Meddling with a WispRe: Jay Rivett Jay Rivett 04/19/23 10:12AM
  Re: Meddling with a WispRe: James P James P 04/18/23 07:53PM
