Tuning a vm18 Mikuni
Sooooo...
Yeah I am trying to step up my carburetor game. Don't know why I chose the vm18 over a phbg, but I did. So here we are.
I have not changed out the atomizer or the needle. I have changed out the main jet and the idle jet trying to get the bike to run better with the throttle more than 1/2 open.
I started at a 30 idle jet with a 100 main jet.
The bike started easily with the 30 idle, but after heat cycling to break in the kit, the plug had a lot of carbon build up so I figured that was too big so I went down to a 25.
The 100 main jet with the needle in the middle position bogged down and killed the engine at any throttle position. I dropped the needle to the top position and the bike gained some throttle responce. It would still bog and die at WOT though.
Now here is where I am still trying to understand things.
By dropping the needle down it closes off the fuel, leaning out the mix. So that says to me that I would want to down jet my main.
I down jetted to a 95 main and kept the needle in the same position. The bike has some more throttle response than before but still bogs at WOT. I did take the bike for a spin and just had to half throttle up to speed, hit 38mph but it started bogging when trying to open up the throttle all the way so I backed it off.
I checked the plug after my run and it looks a bit too lean. I have not played with the needle just yet, but will it richen things up enough?
Is there any difference in feel or sound between a lean bog vs a rich bog?
My temp gauge never got up over 310, but I was not running for very long.
Setup:
70cc tccd kit w/low comp head
Mlm peoples pipe
Vm18
Re: Tuning a vm18 Mikuni
Emil Kniemel /
Your bog is probably four stroking. 25 is still pretty rich. People are usually closer to 15.
edit: vm18 has an air mixture screw rather than a fuel mixture screw so i had to reverse what i posted:
Tune the idle first. Start with a warm engine and the air mixture screw 2.5 turns out from flush (a full turn is 180 degrees. Adjust it by 1/4 turn at a time, blipping the throttle each time.) Turning it IN richens the idle mix, turning OUT leans it out.
If you can close the air mixture screw IN to 1 or less turns from flush with no difference, then you need to go DOWN a size on your idle jet cuz you're too rich. If the engine "hangs" after you blip the throttle it is too lean. You will know you have the right size idle jet when it idles smoothly and returns to idle smoothly after a blip, and the air mixture screw is between 3 and 2 turns out. (edited)
Jay Rivett /
Thanks for some answers and ideas! I am going to get into it some more this week!
For reference, the setup on a 70cc tomos i kitted with a VM20 and pipe I had a 22.5 idle, 85 main, leanest needle position. Felt it could even be a little leaner still.
Jay Rivett /
This is all very good info. If anyone else can share their numbers especially in their vm18 that would be super helpful as reference points. I appreciate all the help, I know I can get this guy set up right!
Yeah your main is way huge... VM18 runs 75, 80, or 85 on almost all moped builds I've used them. The idle is usually 17, 20 or 22.
Jay Rivett /
Graham!
That is a huge help and I have all of these jets!
Gonna mess with it some tonight I hope. I think the monsoons are coming and finally giving us a little break from this heat.
za50
vm18 on tccd70
Techno circuit pipe
High flow filter.
I think I settled around 17.5 idle and 75 main, I'll check to be sure when I get home I usually write down whats in there
Dirty30 Dillon /
Yeah, I was always so surprised how small my VM18 jets ended up in comparison to the VM20. on similiar setups.
Jay Rivett /
Super helpful info for those of us just starting out on there kinds of carbs! Thanks everyone!
Jared, how do you like that tccd on the za50? It is where mine will end up once I get the za50 rebuilt that I have.
Yeah, they are totally different carbs, mikuni almost should have just named them something totally different. All the tuning parts besides the main jet are totally different.
The other thing I was gonna say... These can be tricky to get right because they don't four stroke or run funny like a phbg if the jetting is slightly off... That's nice for getting an initial tune and getting it running, but annoying for fine tuning.
The way I have found works best is to go with a small pilot jet and a big main. Work your way down on the main until the temp starts going up, the plug chops are correct or it starts to 'feel lean' if you can feel it. After a few years you can feel when it's lean but for starters the head temp gauge is the best. I usually wait until after break in before doing a plug chop, and sometimes if it's running good I don't even do one, I just check the plug and go 'yup'
Every time you change main, you will need to adjust the screw but leaving the pilot jet too small, you will notice right away when it's lean. Then start going bigger on the pilot jet until your screw is between 1 and 2.5 turns out. Turn the screw listening for the idle to raise, that will get you within about 1/2 turn off being right, then go quickly from 0-1/2 throttle repeatedly until it has the quickest and cleanest sounding rev up. You will also need to move the needle up and down. If the spot where the screw wants to be at idle, and the spot where the screw wants to be for a clean rev up are 2 different places, that will tell you your needle needs to move.
Once you understand the logic of these carbs they are super easy to tune and they really run well. If you are just randomly flipping parts around until it works, you will be frustrated.
Jay Rivett /
Graham this is exactly what I needed. I had read thru the mikuni vm tuning guide I found on the wiki but it is definitely for bigger carbs on multi gear bikes. It gave me some ideas on some tuning aspects but it was still pretty greek over all to me.
I do have a basic grasp of what is happening when I make adjustments and how to follow, but I also suspected I would not get the same "four stroking" and other indications that I get from a sha. So I am hoping that I will be able to get this little guy tuned up real nice. Perfect would be great, but not seizing is all I really need. With it over jetted I already hit a good speed so I'm not trying to get too much more out of it.
Jay, I think those are great kits for the money. I have 1 on a za dirtped and one on an e50 maxi. The za is geared pretty low but I wanted torque not top speed. It'll lift the front when I want it to and tops around 38.
Emil Kniemel /
Do you count a "turn" as a full turn (360) or half turn (180) ?
I fucked up and typed 180 in my earlier post, but i meant 360. A full turn is always 360. i just suck at circles
Emil Kniemel /
haha i was thinking that i count 180s as half turns. so when i am setting carbs it will be like 3 half turns vs 1.5 turns. i dunno why. easier for me to count that way.
Haha yeah I do the same thing, that's how you hold a screwdriver! I do the math in my head because all the service manuals specify 360 deg full turns and it's easy to communicate that way
I saw this posted the other day and saved it.. Maybe it will help you out?
http://www.vintagebikebuilder.com/mikuni-tuning-and-jetting-guide.html
Jay Rivett /
I always count a turn as 360. But I always count in 1/2s when I'm turning too. Thanks again for the helpful info!
Jay Rivett /
> out?
Reading thru this. Good stuff. Brain melting info. This chart tho...
Super confused about your turns out, haha. Should be a flat blade screw driver and turn from dead stop out 180 equals half turn. So if you turn the blade 180 three times it will be at one and a half turns. You say three turns out and that is to much haha. I always say half, half, half. Haha fuck it.
Yeah read in "flat view" and see my previous post, i just spaced and wrote 180 rather than 360. sometimes i do wish you could edit old posts on here, now i've made another contribution to future confusion ugh.
Jay Rivett /
Someone posted this page up yesterday and it has been a good read on the understanding of how these carbs work. I have skipped over some of the history and basics, there is a lot of info about the carb. This, like other mituni tuning items I have read is primarily working with 24mm+ carbs and on multi geared bikes, but the understanding of the jets is all the same.
mikuni tuning
That drove me to the bottle. If only somebody made a TL;DR for it. I thought my knowledge of carbs was limited before reading this write-up, now I realize it's beyond that. Apparently replacing Honda and Stihl lawn tools over the years was not a great precursor to precise tuning.
Just here to say that on the contrary to all I've read and experienced with vm18, I'm blown away by how large of a jet my 65cc metrakit pyramid Reed engine wants with it. It wanted a jet in the high 130's low 140's. Leakdown tested, nothing amiss.
Emil Kniemel /
> all the same.
> mikuni tuning
Damn that is a lot of reading. I always thought that the "choke" on mikuni was fuel enrichment and not air choke (eventhough its clearly labeled choke). guess i was wrong.
Mikuni jets are always up there in size compared to dellorto
Dirty30 Dillon /
Take this with a grain of salt, because obviously carb design plays such a large part in how a jet functions, but this is a useful chart for people trying to cross-ref jet sizing.
Have you WIKIed this chart ? It should be there .
