Re: Jawa cylinder reed conversion
Sean Mohoot /
The holes actually meet right up dead center, the only thing is that the Jawas have 5mm studs. Thinking of re-tapping them out to 6mm, there isn't a ton of meat beside the stud holes with the reed block in mind, but I may just go out on a limb and try it out. See how cute this could be? Lil guy might just snuggle right down in there after some VERY careful dremel work :)
  Jawa cylinder reed conversionTopic by: Sean Mohoot Sean Mohoot 06/24/20 03:00AM
  Re: Jawa cylinder reed conversionRe: Sean Mohoot Sean Mohoot 06/24/20 03:21AM
  Re: Jawa cylinder reed conversionRe: Sean Mohoot Sean Mohoot 06/24/20 04:03AM
  Re: Jawa cylinder reed conversionRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 06/24/20 04:39PM
  Re: Jawa cylinder reed conversionRe: Dirty30 Dillon Dirty30 Dillon 06/24/20 04:44PM
  Re: Jawa cylinder reed conversionRe: Sean Mohoot Sean Mohoot 03/07/21 02:07PM
  Re: Jawa cylinder reed conversionRe: Matt Decker Matt Decker 01/08/22 06:59PM
  Re: Jawa cylinder reed conversionRe: Vlado vlado Vlado vlado 01/11/22 07:59PM
  Re: Jawa cylinder reed conversionRe: Matt Decker Matt Decker 01/13/22 10:42PM
  Re: Jawa cylinder reed conversionRe: Mike Boyd Mike Boyd 06/24/20 06:42PM
  Re: Jawa cylinder reed conversionRe: Kevin Bishop Kevin Bishop 06/24/20 10:58PM
  Re: Jawa cylinder reed conversionRe: Totally normal JBOT Totally normal JBOT 06/27/20 11:52PM
  Re: Jawa cylinder reed conversionRe: Totally normal JBOT Totally normal JBOT 06/27/20 11:56PM
  Re: Jawa cylinder reed conversionRe: * wormdirt * * wormdirt * 06/28/20 01:18AM
  Re: Jawa cylinder reed conversionRe: Frank Bailey Frank Bailey 06/28/20 08:48AM
  Re: Jawa cylinder reed conversionRe: Frank Bailey Frank Bailey 06/28/20 09:20AM
  Re: Jawa cylinder reed conversionRe: Totally normal JBOT Totally normal JBOT 06/28/20 01:44PM
  Re: Jawa cylinder reed conversionRe: Frank Bailey Frank Bailey 06/28/20 02:32PM
  Re: Jawa cylinder reed conversionRe: Ben Whittle Ben Whittle 06/28/20 05:19PM
  Re: Jawa cylinder reed conversionRe: Frank Bailey Frank Bailey 06/28/20 05:26PM
  Re: Jawa cylinder reed conversionRe: Ben Whittle Ben Whittle 06/28/20 10:52PM
  Re: Jawa cylinder reed conversionRe: Totally normal JBOT Totally normal JBOT 06/28/20 01:48PM
  Re: Jawa cylinder reed conversionRe: Totally normal JBOT Totally normal JBOT 06/28/20 09:50PM
  Re: Jawa cylinder reed conversionRe: Frank Bailey Frank Bailey 06/28/20 10:58PM
  Re: Jawa cylinder reed conversionRe: will warn will warn 06/29/20 09:46PM
  Re: Jawa cylinder reed conversionRe: B the Moped B the Moped 07/03/20 01:31AM
  Re: Jawa cylinder reed conversionRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 07/03/20 10:50AM
  Re: Jawa cylinder reed conversionRe: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang 12/01/20 11:29AM
  Re: Jawa cylinder reed conversionRe: pat splat pat splat 12/26/20 08:38AM
