Re: Bolt on hobbit swingarm extension and shock extension
Totally normal JBOT /
Well I fixed everything. Sanded the outside of the clips and used a dental tool to dig out the center of the clip slots.. clips seat in nice now and are hard to spin.
Saw why the pin was a lil loose, one side of the casting is missing a bit of alu where the pin goes thru inside the piston so it doesn’t have as much pin bore as the other side. Nbd, it’ll run for awhile.
Just gotta finish the pipe tomorrow and I get to test the bolt on mount and the new engine setup. I also attempted to bore a 21mm OKO into a 26mm OKO. It looks promising after cleaning and blowing it out and putting it all back together. We’ll see if it works.
  Bolt on hobbit swingarm extension and shock extensionTopic by: Totally normal JBOT Totally normal JBOT 06/14/20 12:47AM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: 666 420 666 420 06/14/20 01:53AM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Totally normal JBOT Totally normal JBOT 06/14/20 02:01AM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Satan 666 Satan 666 06/14/20 07:26AM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Totally normal JBOT Totally normal JBOT 06/14/20 11:20AM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Dirty30 Dillon Dirty30 Dillon 06/14/20 11:19AM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Joel P Joel P 06/14/20 12:21PM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Travis Noll Travis Noll 06/14/20 11:14PM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Totally normal JBOT Totally normal JBOT 06/14/20 11:21PM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Travis Noll Travis Noll 06/15/20 12:08AM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Travis Noll Travis Noll 06/15/20 12:09AM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Mike Boyd Mike Boyd 06/14/20 11:56PM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Totally normal JBOT Totally normal JBOT 06/15/20 12:15AM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Totally normal JBOT Totally normal JBOT 06/15/20 12:17AM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Totally normal JBOT Totally normal JBOT 06/15/20 12:54AM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Totally normal JBOT Totally normal JBOT 06/15/20 07:36PM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Totally normal JBOT Totally normal JBOT 06/15/20 07:50PM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Emil Kniemel Emil Kniemel 06/16/20 11:59AM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Totally normal JBOT Totally normal JBOT 06/16/20 12:12PM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Kevin Bishop Kevin Bishop 06/15/20 07:54PM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Totally normal JBOT Totally normal JBOT 06/15/20 09:57PM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: 666 420 666 420 11/15/20 02:24AM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Kevin Bishop Kevin Bishop 06/17/20 02:10PM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Totally normal JBOT Totally normal JBOT 06/17/20 11:00PM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Totally normal JBOT Totally normal JBOT 02/07/21 10:02PM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Totally normal JBOT Totally normal JBOT 02/08/21 11:05AM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: 666 420 666 420 02/08/21 02:27PM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Totally normal JBOT Totally normal JBOT 02/08/21 11:09PM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: classic carl jepsen classic carl jepsen 11/18/20 07:18PM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Totally normal JBOT Totally normal JBOT 11/18/20 08:24PM
