Re: Bolt on hobbit swingarm extension and shock extension
Kevin Bishop /
He obviously did but you’d have to run it at bonneville because it was a 1 speed. The fastest 50cc was a Garelli with Kreidler motor but it had 12 gears. You are on the right track with variated “gears”. Do four bells or you’re not trying! Just like a semi shift it from low to high when you reach max variation. Put your second set of pulleys on a launch lever so when it engages the low disengages. Suicide style. It would be hard to downshift.
  Bolt on hobbit swingarm extension and shock extensionTopic by: Totally normal JBOT Totally normal JBOT 06/14/20 12:47AM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Pussy Licker420 Pussy Licker420 06/14/20 01:53AM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Totally normal JBOT Totally normal JBOT 06/14/20 02:01AM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Satan 666 Satan 666 06/14/20 07:26AM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Totally normal JBOT Totally normal JBOT 06/14/20 11:20AM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Dirty30 Dillon Dirty30 Dillon 06/14/20 11:19AM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Joel P Joel P 06/14/20 12:21PM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Travis Noll Travis Noll 06/14/20 11:14PM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Totally normal JBOT Totally normal JBOT 06/14/20 11:21PM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Travis Noll Travis Noll 06/15/20 12:08AM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Travis Noll Travis Noll 06/15/20 12:09AM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Mike Boyd Mike Boyd 06/14/20 11:56PM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Totally normal JBOT Totally normal JBOT 06/15/20 12:15AM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Totally normal JBOT Totally normal JBOT 06/15/20 12:17AM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Totally normal JBOT Totally normal JBOT 06/15/20 12:54AM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Totally normal JBOT Totally normal JBOT 06/15/20 07:36PM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Totally normal JBOT Totally normal JBOT 06/15/20 07:50PM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Emil Kniemel Emil Kniemel 06/16/20 11:59AM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Totally normal JBOT Totally normal JBOT 06/16/20 12:12PM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Kevin Bishop Kevin Bishop 06/15/20 07:54PM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Totally normal JBOT Totally normal JBOT 06/15/20 09:57PM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Pussy Licker420 Pussy Licker420 11/15/20 02:24AM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Kevin Bishop Kevin Bishop 06/17/20 02:10PM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Totally normal JBOT Totally normal JBOT 06/17/20 11:00PM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Totally normal JBOT Totally normal JBOT 02/07/21 10:02PM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Totally normal JBOT Totally normal JBOT 02/08/21 11:05AM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Pussy Licker420 Pussy Licker420 02/08/21 02:27PM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Totally normal JBOT Totally normal JBOT 02/08/21 11:09PM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: classic carl jepsen classic carl jepsen 11/18/20 07:18PM
  Re: Bolt on hobbit swingarm extension and shock extensionRe: Totally normal JBOT Totally normal JBOT 11/18/20 08:24PM
