Repacking a proma baffle
I just got a proma for my Hobbit, and as I understand it the baffle that comes with it is packed pretty tight, which contributes the hellish volume of this pipe.
I've never repacked a baffle before, but my understanding is that it's pretty straight forward (pull out the tube in the middle, remove some of the batting, rewrap and shove it back in). I'm just not positive on how to open it up, so rather than bruting my way through it and risking breaking anything, I thought I'd ask you kind folks.
I attached a picture of each end - I'm guessing I need to remove the little circlip in the second picture? Do I just use some pliers to pull it out, or is there a certain technique to it?
Re: Repacking a proma baffle
yep, thats the way to do it. remove the circlip and it should slide out. you could try experimenting with different grades of steel wool or using an alternative material
Jessie Paull /
What's the best way to get the circlip out?
Use a circlip tool?
Cir-clip/snap ring pliers usually work pretty good :
operator error 696 420 /
I’m not a fan of the blue tape but clear masking tape instead
You’ll probably fuck up the first few times! I did. It’s like griping your first skateboard, you gotta learn some how!!!!!!!!!!!
I was born a pro lol
Jessie Paull /
> https://imgaz.staticbg.com/thumb/view/oaupload/banggood/images/69/39/f2c0b991-a22e-48eb-9086-89b25bb9320c.jpg
Thanks a lot, the picture helped.
This is the first time I've ever worked on anything automotive, so I'm still learning what tools are for what and all that. I end up calling my dad to borrow things a lot hah
Jessie Paull /
Just finished putting it all back together - fingers crossed I didn't fuck anything up too bad!! Wish I wore gloves thooo haha
♣Slew Foot♣ /
Marbles instead of fiberglass for da win.
