MB5 Oil Pump Delete Question
I bought a blockoff plate, can i just remove the external portion of the pump or do i need to crack open the case and remove the gear and whatever is inside related to the pump?
thanks!
Re: MB5 Oil Pump Delete Question
Just pull the pump off and block the hole. The power it takes to drive the internal gear is miniscule. No need to make a headache for yourself.
Thanks! Been putting it off for a while because i didn't know.
