wet oily spark plug
Hey all,
I replaced my spark plug yesterday for the first time in about a half a year. It came out real nasty looking and I’m wondering if this is normal short i replace them more frequently?
a little information on the build.
it’s a minarelli V1
15mm sha
80cc polini
peoples pipe
all ports matched
i usually do a 50:1 oil mix
the bike runs really well but if anyone know a anything about how to fix this, or if it’s just normal anything would be helpful
thanks!!
Re: wet oily spark plug
Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F /
Uhhhh, did you clean out the engine completely when you port matched? some of those bits look a little shinny
Jack Bartow /
I thought so, but must have missed quite a bit there. good eye!
If it is metal, do a full rebuild, not worth seizing the bottom end, if metal flakes are on the plug, they are also in the bearings. Good luck
I can't see the pict.
Jack Bartow /
hopefully this link works.
Here it is :
Right click on the image in imgur . Right click and hit 'copy image address' .
Click the photo icon above the reply box here and past the address in the drop down .
Hit OK .
Of course , post your message before or after ... (edited)
BTW , that^ plug looks way too rich , to me .
looks sooty, like its burning oil, is it smoking a ton? like look in the rear view mirror and u can see a cloud? is tranny oil low?
Is that metal? or is that just the sheen from oil
Jack Bartow /
the exhaust looks fine there’s a bit of smoke that’s come from the outside of the pipe when it’s warming up.
Jack Bartow /
I thought it was oil. i can’t think of any reason metal shards were able to get ahead of the piston.
intake ports/ transfers
