Re: E50 case prep Q's
Stan Shingler /
Thanks for the advice... will just clean up the case as best I can then.
I think I solved the question about whether I should remove and smooth the transfer deep in the case; I mocked the crank in place and determined that if I did that, then the flow would hit the sides of the crank lobes rather than pass and mingle above it. There doesn't seem to an advantage so I'll just leave them be.
