Piston/cylinder ping question
My stock a35 is running great. But there's 2 Minor issues can't be normal and I need guru advise please? When I slow down and go to open throttle it falls for a second on its face then accepts the throttle runs good except for beginning the throttle hesitant for split second like then takes the throttle. 2nd issue is a ping sound in the cylinder and piston. It's got Cocoa plug b6hs ngk 62 jet dellorto 1412. Help appreciated thanks in advance
Re: Piston/cylinder ping question
Check your ignition timing
Thanks rebel
Needle position, slide cutaway, idle jet size all affect transition and throttle from closed to 1/2 open
♣Slew Foot♣ /
That tiny leprechaun bowl ie snorkel helps it not bog go a step hotter on the plug or get a non fowl one. I just baby it on yak÷ off its works like a theft deterant they stall it you catch them a block away. Dead man throttle so you manually have to keep the idle.
It idles great. When you take off It gives you canoeing form. Forward to.h backwards winnngggg! Lol and I got burned rust into the piston crown because of rusty tank. Few problems for sure.
She's fine now. That pinging cylinder sounds stopped after I went from#60 to jet#62 and packed the silencer really tight. Better take off and damp plug.
