Re: Variator Tuning For Low End Acceleration
Jack Rutherford /
Run a 9325 belt and experiment with variator weights from 30-39 grams given your stock exhaust. You can also add the shortest 14” rear tire you can find. Check your compression and if anywhere between 90-120, raise it 30 or so psi. Too rich a main jet will kill acceleration as will poor spark as will a poor seal between cylinder and exhaust. As will a carboned up exhaust. And of course check for rust and pitting on your pulleys in addition to oil or grease on pulleys or belt.
You also want the red clutch springs on a gy6 clutch. As far as contra, probably a yellow contra. I would think a heavier gauge contra would hurt acceleration. (edited)
  Variator Tuning For Low End AccelerationTopic by: Real Deal Neil Real Deal Neil 05/20/20 10:59PM
  Re: Variator Tuning For Low End AccelerationRe: Chris . Chris . 05/20/20 11:49PM
  Re: Variator Tuning For Low End AccelerationRe: Jack Rutherford Jack Rutherford 05/21/20 12:50AM
  Re: Variator Tuning For Low End AccelerationRe: Real Deal Neil Real Deal Neil 05/21/20 10:28PM
  Re: Variator Tuning For Low End AccelerationRe: Real Deal Neil Real Deal Neil 05/22/20 11:59PM
  Re: Variator Tuning For Low End AccelerationRe: Justabunchoftrash 646260 Justabunchoftrash 646260 05/23/20 02:04AM
  Re: Variator Tuning For Low End AccelerationRe: Dirty30 Dillon Dirty30 Dillon 05/23/20 09:40AM
  Re: Variator Tuning For Low End AccelerationRe: Justabunchoftrash 646260 Justabunchoftrash 646260 05/23/20 09:38PM
  Re: Variator Tuning For Low End AccelerationRe: Dirty30 Dillon Dirty30 Dillon 05/23/20 09:44PM
  Re: Variator Tuning For Low End AccelerationRe: Justabunchoftrash 646260 Justabunchoftrash 646260 05/23/20 10:05PM
  Re: Variator Tuning For Low End AccelerationRe: Dirty30 Dillon Dirty30 Dillon 05/23/20 10:38PM
  Re: Variator Tuning For Low End AccelerationRe: Justabunchoftrash 646260 Justabunchoftrash 646260 05/23/20 10:55PM
  Re: Variator Tuning For Low End AccelerationRe: Ike Pipe Ike Pipe 05/25/20 12:42AM
  Re: Variator Tuning For Low End AccelerationRe: Dirty30 Dillon Dirty30 Dillon 05/25/20 01:28AM
  Re: Variator Tuning For Low End AccelerationRe: Ike Pipe Ike Pipe 05/25/20 04:36PM
  Re: Variator Tuning For Low End AccelerationRe: P D P D 05/25/20 05:00PM
  Re: Variator Tuning For Low End AccelerationRe: Justabunchoftrash 646260 Justabunchoftrash 646260 05/25/20 07:09PM
