Re: 78 Maxi full build
Mike Boyd /
If you're doing a top down rebuild then you should consider replacing brake shoes (depending on wear), rebuilding and greasing the brake plates, and repacking and re-greasing the wheel bearings (or better yet switch to sealed bearing axle conversion, especially for the rear wheel at least)
