Seat was way too close and too high. So I cut off the top bar and welded in a flat bar lower, moved the seat back and now it blends in much better.
Motor's mounted and it starts, so that's a good thing. I opened up the ports like twice the size, welded more metal on the jug near the transfers so I could open them way up.
Also welded more metal around the intake so I could open that up, too
Not supposed to weld cast iron? Whatever. It doesn't leak.
Also made some finger ports, drilled the piston to match. Didnt take any pictures, sorry.
Polini CP 17.5 carb. Pancake fart box on to test start it, gotta build a pipe.
Dansi can-type coil hidden up above the motor in the big empty space.
Waiting on a 36 rear sprocket. Gonna have to drill it to fit the weird 3bolt hub, because all I see are big ass sprockets for lazers and generals.
Pretty confident it'll do 50+.
