Re: Crank for a vespa reed valve case half
Jason ( ͡° ͜ʖ ͡°) /
So I ordered the small case half, I'm bent on trying this one way or another. I have no doubt I could drill a nice little hole in one of my stock cranks . . . . but the concern is then that I will be pushing way too much RPM for not having a needle bearing crank lol. Worth a try? Maybe. But probably not. Better just to do it right.
Although that pinasco crank that they link is like $300, mazzy also makes one that is only 145 ... but its out of stock (https://www.treatland.tv/mazzucchelli-vespa-12-pin-special-race-crank-p/mazz-vespa-crankshaft-amt204.htm).
If/when I can get that . . . I would be looking at only about $225 total, and an extra carb and filter I already have lying around. And a lot of jets for tuning. I think this is totally doable. And how fun would it be to tune the second carb to kick in later in the throttle pull!?!?!?!
  Crank for a vespa reed valve case halfTopic by: Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F 05/14/20 12:40PM
  Re: Crank for a vespa reed valve case halfRe: Dirty30 Dillon Dirty30 Dillon 05/14/20 01:23PM
  Re: Crank for a vespa reed valve case halfRe: Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F 05/14/20 01:25PM
  Re: Crank for a vespa reed valve case halfRe: Dirty30 Dillon Dirty30 Dillon 05/14/20 01:32PM
  Re: Crank for a vespa reed valve case halfRe: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 11/19/20 03:31PM
  Re: Crank for a vespa reed valve case halfRe: Dirty30 Dillon Dirty30 Dillon 11/19/20 03:48PM
  Re: Crank for a vespa reed valve case halfRe: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 11/19/20 04:29PM
  Re: Crank for a vespa reed valve case halfRe: Dirty30 Dillon Dirty30 Dillon 11/19/20 04:48PM
  Re: Crank for a vespa reed valve case halfRe: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 11/19/20 11:23PM
  Re: Crank for a vespa reed valve case halfRe: Dirty30 Dillon Dirty30 Dillon 11/19/20 11:48PM
  Re: Crank for a vespa reed valve case halfRe: todd amundson todd amundson 11/20/20 01:42PM
  Re: Crank for a vespa reed valve case halfRe: EH FCC of the QCB EH FCC of the QCB 11/20/20 07:22PM
  Re: Crank for a vespa reed valve case halfRe: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 11/23/20 08:34PM
  Re: Crank for a vespa reed valve case halfRe: todd amundson todd amundson 11/24/20 01:41PM
  Re: Crank for a vespa reed valve case halfRe: - Joe - - Joe - 11/24/20 05:34PM
  Re: Crank for a vespa reed valve case halfRe: Graham Motzing Graham Motzing 11/19/20 09:23PM
  Re: Crank for a vespa reed valve case halfRe: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 11/19/20 11:26PM
  Re: Crank for a vespa reed valve case halfRe: todd amundson todd amundson 11/23/20 12:30PM
  Re: Crank for a vespa reed valve case halfRe: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 11/23/20 08:46PM
