Re: Crank for a vespa reed valve case half
Jason ( ͡° ͜ʖ ͡°) /
> todd amundson Wrote:
> While I have not tried what you’re talking about, I’m sure it would work
> with one carburetor sticking out the side, with any crank that’ll fit in
> the case. The charge will have enough time to flow through a full web
> crank or a cut crank. It’s not ideal but it should work really well.
> Here’s stock cases with the intake moved up top. The little stock nipple
> is closed. I use one oko 21 on the set up. It shoots right on top of the
> left crank lobe. Cranks full circle malossi
> Ps, ignitions more important
This thing is so wild. Do you have any pics of the intake that you run with this? Is it custom or did you build the opening to work for a specific existing intake?
Speaking of ignitions, what are you running on that? What's the huge slot into the stator for?
  Crank for a vespa reed valve case halfTopic by: Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F 05/14/20 12:40PM
  Re: Crank for a vespa reed valve case halfRe: Dirty30 Dillon Dirty30 Dillon 05/14/20 01:23PM
  Re: Crank for a vespa reed valve case halfRe: Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F 05/14/20 01:25PM
  Re: Crank for a vespa reed valve case halfRe: Dirty30 Dillon Dirty30 Dillon 05/14/20 01:32PM
  Re: Crank for a vespa reed valve case halfRe: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 11/19/20 03:31PM
  Re: Crank for a vespa reed valve case halfRe: Dirty30 Dillon Dirty30 Dillon 11/19/20 03:48PM
  Re: Crank for a vespa reed valve case halfRe: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 11/19/20 04:29PM
  Re: Crank for a vespa reed valve case halfRe: Dirty30 Dillon Dirty30 Dillon 11/19/20 04:48PM
  Re: Crank for a vespa reed valve case halfRe: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 11/19/20 11:23PM
  Re: Crank for a vespa reed valve case halfRe: Dirty30 Dillon Dirty30 Dillon 11/19/20 11:48PM
  Re: Crank for a vespa reed valve case halfRe: todd amundson todd amundson 11/20/20 01:42PM
  Re: Crank for a vespa reed valve case halfRe: EH FCC of the QCB EH FCC of the QCB 11/20/20 07:22PM
  Re: Crank for a vespa reed valve case halfRe: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 11/23/20 08:34PM
  Re: Crank for a vespa reed valve case halfRe: todd amundson todd amundson 11/24/20 01:41PM
  Re: Crank for a vespa reed valve case halfRe: - Joe - - Joe - 11/24/20 05:34PM
  Re: Crank for a vespa reed valve case halfRe: Graham Motzing Graham Motzing 11/19/20 09:23PM
  Re: Crank for a vespa reed valve case halfRe: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 11/19/20 11:26PM
  Re: Crank for a vespa reed valve case halfRe: todd amundson todd amundson 11/23/20 12:30PM
  Re: Crank for a vespa reed valve case halfRe: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 11/23/20 08:46PM
