Re: Crank for a vespa reed valve case half
Jason ( ͡° ͜ʖ ͡°) /
Has anyone actually physically tried this with a regular vespa crank with no hole in it?
The description says "with the reed valve strangely blastin straight thru the case half bearing" and if you look a the reed opening it's extra wide .... so I think it may be designed so that fuel can make its way THROUGH the unsealed bearing, under the crank web and around the sides .... then into the combustion zone. I really want to try it lol.
  Crank for a vespa reed valve case halfTopic by: Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F 05/14/20 12:40PM
  Re: Crank for a vespa reed valve case halfRe: Dirty30 Dillon Dirty30 Dillon 05/14/20 01:23PM
  Re: Crank for a vespa reed valve case halfRe: Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F 05/14/20 01:25PM
  Re: Crank for a vespa reed valve case halfRe: Dirty30 Dillon Dirty30 Dillon 05/14/20 01:32PM
  Re: Crank for a vespa reed valve case halfRe: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 11/19/20 03:31PM
  Re: Crank for a vespa reed valve case halfRe: Dirty30 Dillon Dirty30 Dillon 11/19/20 03:48PM
  Re: Crank for a vespa reed valve case halfRe: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 11/19/20 04:29PM
  Re: Crank for a vespa reed valve case halfRe: Dirty30 Dillon Dirty30 Dillon 11/19/20 04:48PM
  Re: Crank for a vespa reed valve case halfRe: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 11/19/20 11:23PM
  Re: Crank for a vespa reed valve case halfRe: Dirty30 Dillon Dirty30 Dillon 11/19/20 11:48PM
  Re: Crank for a vespa reed valve case halfRe: todd amundson todd amundson 11/20/20 01:42PM
  Re: Crank for a vespa reed valve case halfRe: EH FCC of the QCB EH FCC of the QCB 11/20/20 07:22PM
  Re: Crank for a vespa reed valve case halfRe: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 11/23/20 08:34PM
  Re: Crank for a vespa reed valve case halfRe: todd amundson todd amundson 11/24/20 01:41PM
  Re: Crank for a vespa reed valve case halfRe: - Joe - - Joe - 11/24/20 05:34PM
  Re: Crank for a vespa reed valve case halfRe: Graham Motzing Graham Motzing 11/19/20 09:23PM
  Re: Crank for a vespa reed valve case halfRe: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 11/19/20 11:26PM
  Re: Crank for a vespa reed valve case halfRe: todd amundson todd amundson 11/23/20 12:30PM
  Re: Crank for a vespa reed valve case halfRe: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 11/23/20 08:46PM
